Hi ihave problem Misfiring after kick down
Old May 16, 2021 | 05:57 AM
Roy mb's Avatar
Ml350 w164 2009 and w204 c200 cdi 2008
I push my paddle to kick down and my car start rattle and check engine light came,
I riplace coil and riplace sparck plug on 3+6 and the problem Stayed the same help please,
Old May 17, 2021 | 03:44 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
The first code cannot be fully seen XX22.
Old May 17, 2021 | 04:50 AM
BlackML550's Avatar
2010 ML550 VIN WDC1641722A564750, 2010 B180
Have you done any other work before the problem began? Something as simple as a vacuum leak created by a poor fitting air filter can give you misfire codes.
Old May 22, 2021 | 04:51 AM
Roy mb's Avatar
The mechanic think its engine ecu need to replace, is checked from ecu wire that go to injection 3+6
And its not get Pulses of minus that makes them work,
In the others injector is see pulses minus
What do you think
