2008 ml320 Black Death and intake air temperature sensor
ml320
I had Black Death on the passenger side closest to the fire wall. When I tested the injectors they were all bypassing fuel at idle. I had another set of injectors from the engine removed from it. Same part number and year. Put all six in the engine with new copper seals and bolts. Only code I had was the intake air temperature sensor which I replaced after the injectors. The problem is it turns over but will not start. No trouble codes at all now. New battery five months ago. I am stumped on this one! I have checked the fuel, checked the fuses and nothing. Is there any suggestions out there?
