Electrical connection problem, battery tests and slow cranking
The car always starts but it also always cranks slow like it has a weak starter. I want to dig into the power cables and connectors but I don't know where to start or if there's any other special things to check with these advanced German vehicles. Something is causing a problem between battery and battery-posts under hood as well as to the starter.
The car has virtually no corrosion and overall drives like new. Relays, power cables, ground. I should mention the tester uses the current not just the voltage for a pass fail
I can see the positive cable harness that runs from the battery area to the positive post, little distribution block, alternator.
Also, that post might not have a large wire going to it. It's an emergency jumpstart post designed to use in conjunction with the existing battery. A better test will be off the starter solenoid.
I did not replace the starter. I was waiting for warmer weather to get to that, but in Feb the battery died after I used the rest function for about 20 min. That prompted me to look closer at the battery and that's when I discovered that it was not the right one. On the plus side, now I have a second spare battery for the boat. The one I pulled out has held a charge well even though I drained it.
All that said, you may still have a starter on its last leg.
If your starter has a braided cable & has corrosion (see arrow), the starter must be replaced.
If not, remove starter and bench test.
thx
