W164-ML350 Engine Fault codes
Edit: I didn't buy this car
____________________
Hello,
i want to buy a w164 car, i found it nice body condition but there is too many problems at the engine dtc, and car is a little bit shakeing when idle.
And also car has Tire pressure Check! , aux battery error, top up coolant, ESP Unavaible and ESP inoperative on the indicator. ELM327 cant see the ESP Faults.
what is your decisions about this DTCs, how much cost will be fix?
i take this diagnose with cheap ELM327.
Owner says he didn't use car for 3 months, and he turn back car is shakeing. (i didn't believe him) he says i'm using company car, and he says i have no time to show car a diagnostic center.
============1==============
P0016
Raw code: 0016
ECU: Engine
OBDII: Crankshaft position/camshaft position, bank 1 sensor A - correlation
===========2==============
P0017
Raw code: 0017
ECU: Engine
OBDII: Crankshaft position/camshaft position, bank 1 sensor B - correlation
============3==============
P0300
Raw code: 0300
ECU: Engine
OBDII: Random/multiple cylinder(s) - misfire detected
Audi: Engine Misfire Detected
============4==============
P0301
Raw code: 0301
ECU: Engine
OBDII: Cylinder 1 - misfire detected
Audi: Cylinder 1 Misfire Detected
============5==============
P0302
Raw code: 0302
ECU: Engine
OBDII: Cylinder 2 - misfire detected
Audi: Cylinder 2 Misfire Detected
============6==============
P0410
Raw code: 0410
ECU: Engine
OBDII: Secondary air injection (AIR) system - malfunction
Audi: Secondary Air Injection (AIR) System
============7==============
P2015
Raw code: 2015
ECU: Engine
OBDII: Intake manifold air control actuator position sensor/switch, bank 1 - range/performance problem
============8==============
P2188
Raw code: 2188
ECU: Engine
OBDII: System too rich at idle, bank 1
============9==============
P2190
Raw code: 2190
ECU: Engine
OBDII: System too rich at idle, bank 2
============10==============
P2300
Raw code: 2300
ECU: Engine
OBDII: Ignition coil A, primary circuit - circuit low
Hello,
P0016
Raw code: 0016
ECU: Engine
P0017
Raw code: 0017
ECU: Engine
P0300
Raw code: 0300
ECU: Engine
P0301
Raw code: 0301
ECU: Engine
P0302
Raw code: 0302
ECU: Engine
P0410
Raw code: 0410
ECU: Engine
P2015
Raw code: 2015
ECU: Engine
P2188
Raw code: 2188
ECU: Engine
P2190
Raw code: 2190
ECU: Engine
P2300
Raw code: 2300
ECU: Engine
Apologies for the lack of information, private owner.
Car is 2007 - ML350 4matic (benzin) - 175.000km (if it is real mileage)
And i'm at kazakhstan.
grkmspr (10-07-2021)
Thx.
i understand, i need replace balance shaft / oil pump also when opened the engine better to change timing chain and chain tensioner. (its about 1.500$ in my country)
well what about the other failures, p0016 and p0017 causes misfire? or coilovers also need to be change? or intake system failure couses misfire?
