State Inspection said rack & pinion was leaking. How to fix?
2008 ML350 4Matic
While getting my vehicle inspected today, the inspector said my rack and pinion was leaking. Not to mention that sometimes the steering gets a little hard while turning sometimes. How can I remedy this problem cost effectively without having to go to the stealership?
08 ML350 4 Matic
08 ML350 4 Matic
Here are the procedures and it is no easy task.
Before you decide anything, check the P/S fluid level. If it is low, fill to proper level and see if the turning the steering wheel prob. disappears.
