2006 ML320 cdi Coolant Temp sensor location
2006 ML320 cdi
Hi there i am new here and have come across a small issue with my ML320 with the fan coming on all the time I had a guy from the AA look at a battery issue and he said that the fan coming on straight away seems like a coolant temp sensor issue.
Does this sound correct if so where can it be located i cant find it anywhere some help on this would be much appreciated
Thakns
Warren
Thakns
Warren
2013 ML350 Bluetec
Does your temperature gauge read abnormally high?
Scanning the car for codes with a scanner like Xentry will, I bet, show a related code that might point you in the right direction. I'd start there before shotgunning parts at it.
