2011 ML550 - Passenger-side blend door sticky?
Old Dec 17, 2023 | 02:29 PM
markloch's Avatar
2011 ML550 2013 GLK350
No codes getting thrown. Blows cold no matter what temp setting, I can sometimes unstick it by setting heat to max.
I haven’t had time to see if it’s isolated to one or more vents (no idea whether there’s one blend door or several).
where to look?
Old Dec 18, 2023 | 04:54 PM
markloch's Avatar
So the passenger side footwell sensor seems to think it’s 78.5C which I’m guessing explains why the passenger-side actuator is at 13% open while drivers-side shows 40C and 100%. Temp at vents are as one would expect given the sensor readings
So wherels the footwell sensor?
Old Dec 23, 2023 | 12:02 PM
markloch's Avatar
Got some help on the other site: drop the panel under the glove box, there’s some conduit (that clips to the panel you just dropped) that carries air from the blower to your feet, it’s in there. $20 part.
Old Dec 23, 2023 | 02:38 PM
Joshinator99's Avatar
ML 63 AMG
Originally Posted by markloch;[url=tel:8896995
8896995[/url]]Got some help on the other site: drop the panel under the glove box, there’s some conduit (that clips to the panel you just dropped) that carries air from the blower to your feet, it’s in there. $20 part.
Thanks for updating us all. Sooner or later someone else will need to fix that too and this will make life easier.
