SRS - passenger connector unplugged?
Old Nov 11, 2024 | 03:40 PM
intel's Avatar
c300
Hi all, I am trying to figure out the SRS light on the gauge cluster. The following codes appeared after a diagnostic scan. Taking a look at the passenger seat I noticed the following was unplugged. Does anyone know where that connects to and if it could be the culprit of the SRS light? Thanks in advanced
2011 ML350 (W164)
Old Nov 17, 2024 | 12:23 AM
intel's Avatar
c300
Might be a long shot, but does anyone have a picture of the connections under their passenger seat?
Old Nov 17, 2024 | 08:06 AM
BlackML550's Avatar
2010 ML550 VIN WDC1641722A564750, 2010 B180
Don't have a photo but isn't the N73 module the Electronic Ignition Switch? Based on the codes you have which appear to be all related to that - have you had any problems starting the car? All Benz's of this era have the EIS fault which is easily fixed. That might be your problem.
Old Dec 4, 2024 | 10:06 PM
lkchris's Avatar
'10 CL550, '12 GL550
An unplugged connector will indeed create an SRS light.
plugging it in will not turn off the warning light.
this can only be done with a fairly sophisticated code reader.
