Mercedes key not locking or unlocking sometimes issue
i have a little issue with my ML 350 2011 w164. Problem is i have two key fobs and they seemed to have bad battery. I changed batteries on both keys and it worked fine for some time.
But now its not unlocking or locking, sometimes it works and sometimes not. I have to push many times and if im lucky it will lock or unlock.
no warning of bad key battery and car is fine, just the issue with the key not always working.
i also tried removing battery and put it back in and then it works fine for some days, then its hard to unlock and lock the car.
is there a resync for the keys? Or any ideas?
In the beginning I had to put my key next to the IR eye to open and I had turn the key in the ignition and take out, close the door and press lock.
One other issue I got the same time was the fuel gate, it went down from 3/4 tank to 1/4 in 20 minutes driving.
I haven't had more issues with locking and opening after changing the rear SAM box, only that it seems to recognition my car as left hand driven. Just only annoying.
I would say check the condition of your rear SAM box because these functions are in that SAM box.
take out the SAM box and open it carefully and inspect after water damage (corrosion)
this is common problem.
