W166 COMAND ONLINE Engineering Mode Description
1 Attachment(s)
Hi everyone!
I am one of the lucky ones by owning a brand new MY13 ML350 4Matic (W166). After reading some comments about COMAND ONLINE, I've decided to discover it myself. I was able to get into the engineering mode by "end call + 1 + #" key combination pressed for about 10 sec. There is also another secret menu after entering the engineering mode as mentioned in some threads in this forum. I managed to enter the second menu with the key combination "end call + 4 + #" after entering the engineering menu. I prepared an instruction with screens from COMAND ONLINE in the attachment for those who wants to bring some cool features on to their COMAND system. I must warn though, you can mess up with your settings. So, don't change anything if you are not sure what you are doing. Good Luck |
Originally Posted by ilke.senol
(Post 5644104)
Hi everyone!
I am one of the lucky ones by owning a brand new MY13 ML350 4Matic (W166). After reading some comments about COMAND ONLINE, I've decided to discover it myself. I was able to get into the engineering mode by "end call + 1 + #" key combination pressed for about 10 sec. There is also another secret menu after entering the engineering mode as mentioned in some threads in this forum. I managed to enter the second menu with the key combination "end call + 4 + #" after entering the engineering menu. I prepared an instruction with screens from COMAND ONLINE in the attachment for those who wants to bring some cool features on to their COMAND system. I must warn though, you can mess up with your settings. So, don't change anything if you are not sure what you are doing. |
You can toggle between the screens by pulling the central control wheel all the way to the south. So, first turn the wheel clockwise to go down to the very bottom of the list in each screen and then pull the wheel to south (towards rear seats), this will take you to the next screen. You can press on the wheel to confirm a selection, just like in normal control. If you change any setting, the system must be restarted before the changes be affective. You should find a menu where there is "END" option available. Once you select it, it will ask you to leave the menu and restart. However, what I noticed is that not all "END" options restart the system for some reason. So if it does not ask for restart, you will loose your changes and need to do it again. I use always the following "END" option which restarts the system: 7.HW settings --> 7.15 USB compliance test
good luck |
Thanks for posting that information ilke.senol.
I had a bit of a play around with this a few weeks ago as I wanted to check-out the different clocks that could be displayed as per the information in https://mbworld.org/forums/new-m-cla...-findings.html I noticed something on page 6 of your PDF which caught my attention: The middle photo where the top of the COMAND screen says "7.7 HU Parameter (11/16)" then below that "71 Vehicle Body Style: W-Sedan". I actually changed mine to SUV thinking it was possibly an error from the factory or something. Anyway, it hasn't seemed to have made any difference with anything. Perhaps I should have left it alone hmmm. Has anyone got any ideas about this? Thanks in advance ... :y |
I played with the same setting as well and no difference. Therefore, I left it in W-sedan. Actually I don't remember any SUV option in that option. I have the same question for the menu item 36-Recircul Air Icon on page 4. It is now SUV selected and when I change it, that doesn't change anything in my settings either. Any idea? Similarly, 44-Split View on page 5 nothing happens
I didn't think
The current W166 had the split view yet ??? I'm assuming in the next few years, that will be an option. Certainly a must have option.
Originally Posted by C-rod
(Post 5646020)
Wonderful.
Thanks for letting me know.
split view = 360 degree camera?
No "split view" is special LCD screen and tech taken from XBox - let's passenger and drive view two formats - more limited than it sounds - see that feature on special option S-Class mostly -
For what it is worth. Even though my Canadian ML does not have split view in Canada, it certainly does while driving in the USA, but only if I don't use metric and have changed the instrument panel to miles.
Here is something which is really strange, today in Montana we got 34.2 mpg average and 35.6 mpg max. Until today our average was 27.6 mpg which did include a lot of mountains, with 15 & 20 mph corners and use of the paddle gears. |
Allow Navigation Destination entry while In Motion?
Does anyone know if the feature to allow allow navigation destination entry while in motion is in one of these Engineering settings? Thanks
No, however you can do it with Vediamo.
Originally Posted by jrsmith_68
(Post 6873461)
Can you please share the procedure how to enable address entry while in motion? Thank you |
Originally Posted by noxowner99
(Post 6942446)
HI there,
(Post 6942494)
Do you have a working version of Vediamo and know how to find the correct .CBF to communicate with your COMAND unit? If so its pretty easy to walk you through it, if not let me know when you get the hardware and software.
Thank you for taking time and answering my questions. I would definitely need some instructions on how to. I am very good at IT but very beginner when it comes to mercedes. Thank you again Devis |
(Post 6942494)
Can you or someone tell me what hardware and software I need? I red some were that I need a Dell laptop but not sure what model. |
Search the net for *******. You will be able to find out all you need to know about the laptop, multiplexer, and software you need. Its not easy and requires significant time investment to understand how to use properly.
Originally Posted by das3000
(Post 6873281)
Speakers stopped working on W166 after i played around
(Post 5644104)
Hi everyone!
I am one of the lucky ones by owning a brand new MY13 ML350 4Matic (W166). After reading some comments about COMAND ONLINE, I've decided to discover it myself. I was able to get into the engineering mode by "end call + 1 + #" key combination pressed for about 10 sec. There is also another secret menu after entering the engineering mode as mentioned in some threads in this forum. I managed to enter the second menu with the key combination "end call + 4 + #" after entering the engineering menu. I prepared an instruction with screens from COMAND ONLINE in the attachment for those who wants to bring some cool features on to their COMAND system. I must warn though, you can mess up with your settings. So, don't change anything if you are not sure what you are doing. Good Luck Hi I found your pdf and explanation very detailed and useful, I am wondering if you may help me on this issue. I did enter Engineering mode using (End call + 1 + * +#)keys which i am not sure if it maid any change rather than using keys without " * ". I quite the setting and I did drive the car and audio was working using SD card. The speakers stopped waking when I returned to SUV. No sound from any devices, Radio, CD, SD, Tel,.... I appreciate your comments. Thanks in advance |
I know it's been a LONG time since you posted this but did you ever get this sorted out. I'm having a similiar problem. I turned AUX on and back off again and now I have no audio and my Media Interface and Sat Radio have disappeared from the menu.
I had the same problem, GL450 with NTG 4.7 with H/K System, enabled AUX in engineering mode and lost sound, Satellite radio and Media Interface, it's taken me a few days but finally figured it out. If you enable AUX in 7.7 HU Parameters , then UCI in 7.5 TGW will show not installed and grayed out which is Media Interface, correct settings for me to get sound, satellite radio and media interface back was as follows:
7.7 HU Parameters - AUX - Not Installed then go to: 7.5 TGW Parameter Most - ON Audio Source - External Amp DAB - not installed SDARS - installed (this is satellite radio) UCI - installed (this is Media Interface) TV Tuner - not installed then perform a 9.1 System Reset In my menu NTG Menu then I had both Media Interface and AUX after this, my MI cable connector has both a 3.5mm input cable and Ipod cable, if connect to the 3.5mm I select AUX in my menu, if I want to use my IPOD I select Media Interface. Hope this helps, save time for some. |
Originally Posted by cguerrero
(Post 8091938)
Originally Posted by csbracing316
(Post 8092029)
This is great info and I wish I’d had it 4 months ago. I tried everything I could think of in the engineering mode menus and researched everywhere I could and could not find anything that would restore my menus. Took it to my Mercedes dealer(which is a large dealer in St Louis) and they couldn’t restore it and had no experience with the engineering menus. So got connected with one of their technology integrators. He was a smart guy that tried some things but couldn’t fix it either. He had a contract/friend at Mercedes who’s and engineer. I had to send it off to him and have it completely reformatted to factory specs with my VIN#. $900 later it’s working perfectly, new firmware and I’ll never play with engineering mode again. Engineering mode is made for setting the unit up at the factory with specific options, and although you can certainly play around with things, I did a number of them successfully, it’s dangerous. And I’m pretty geeky, I’m in communications/tech. Anyway, thanks for the input, but for all the others out there that want to install CarPlay, beware. Be very careful changing inputs!
Yes, I suppose if you take a pic of all the screens you could go back an check them later if something changes. Bottom like, I changed the audio input from the media interface in the center console to the input behind the headunit. Mostly for convenience of running the audio input for apple carplay. I had it connected to the media interface and carplay was working fine. So I changed the input to the AUX behind the head unit, no problems, other than it was an either/or situation, it turned OFF the media interface aux input when I changed it. So my ancient Ipod wouldn't work anymore. So I when I decided to change it back to the media interface... what should have been a simple change to put the AUX input back to the Media interface in the center console, it all died. It greyed out almost all the input in the Engineering screen and nothing, but nothing I would do would change it. Lost my sat radio, media interface, everything, all audio was gone. Head unit still worked but no audio. And with all my personal efforts and pro's I worked with, it would not go back. Only a complete reformat of the headunit restored it. $900 and weeks of headaches and shipping my head unit off. If you're gonna try carplay, be very careful with the Engineering mode.
