Illuminated Star ....mounted!!!!
Hi Friends ... I'm Alfred and i post from Italy...........sorry for some errors.
I've mounted the Illuminated Star on my Ml W 166 .
This is the video of my car
http://www.youtube.com/watch?v=l9WL_...ature=youtu.be
the star lights up when I open the car, and stays on while driving the car.
i 'can still turn it off when you want with a remote control inside the car.
The Star is connected to a dimmer for led and with with i can also adjust the intensity of 'bright
2021 Porsche TTS
Very nice set up.
I know some members will find it too flashy but I like the options you have to turn it off and on with your remote.
I assume this is a custom set up meaning not standard from factory. Can you expand on what you used?
I post some pictures of my work....
it's simple
you can order only the Light Star .....the code for ML W 166 you can read on the box of the picture.
than remove the original star......se the pictures.......it very simple ......rotate to the left and extract..
The Light Star you can connected at the light position lamp ( t 10 5 watt)
Between the Light Star and light position you can use the dimmer in the picture with the remote control you can buy it here for example.....
http://it.dhgate.com/product/dc-12v-...138845322.html
Kind Regards
Alfred
it's simple
Kind Regards
Alfred
2011 C300 4matic, 2015 Porsche Macan S, 2006 R500 (sold)
it's simple
Kind Regards
Alfred
it's simple
Kind Regards
Alfred
Thanks for the video and photos and it looks very cool. Mind to share the picture on how you connect to the power? Btw, the remote control idea is great.
is'very simple .... partially open the plastic cover on right fender. In this way you can see from underneath the large plug that carries current to the entire lantern. Than with a tester you find the positive wire of the position lamp...than with a current tap like you see in the picture you cm take the positive wire for the dimmer. The negative wire from the body car
which color wire did you connect the positive of the star to? can you take a picture? Thanks!
Alfred,
Is the remote control mandatory or is it just an option to control when to have the star light on?
when you remove the old star, will you see all the wiring in it or should you separately wire it?
which year ML350 is it? 2013 or 2014 ?
I will have my 2014 ML350 delivered this week and want to have the illuminated star mounted by myself.
As Stas2007 requested, can you please please please post the pic of the connections so that we dont make any mistake
Alfred,
Ideally the best connection would be to the "orange eybrows" (well they are orange in USA, white everywhere else) since they turn on when you lock/unlock the ML, turn on automatically at night stay OFF during the day.
Considering he doesnt have bi-xenon headlights hence no eyebrows, the remote control connection is probably the best alternative.
Stas2007,
I am from USA, not sure if i have bi-xenon lights. I did not order any special lighting package so assuming i would get the regular ones.
You have mentioned 2 options, to connect to the Orange lights (to have it on only during night) and to connect it to LED lights (to have it on almost all the time the LED lights are on).
Do you know the connections for both these options? Will i be seeing the connection wires once i pull out the existing star?
Look in person is way better, I got my set up here
http://www.ebay.com/itm/Mercedes-Benz-Illuminated-LED-Star-ML-ML350-ML550-ML63-W166-Genuine-2013-13-/121080877368?pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr&hash=item1c30fb9138
they send a module that work with your factory key, all factory parts, the only thing is you can't keep the light on all the time (witch is good for me).
Mercedes Benz Illuminated LED Star ml ML350 ML550 ML63 W166 Genuine 2013 13 | eBay
Run the star on all the time I don't know, I like the way it is, running the star on all the time is a little show off for me but it is a taste issue... maybe you can tap with your headlights..
I've a Ml W 166 2012 with Xenon lamps aftermarket.To connect Only the star is very simple. The star has to wire + and - . The wire - at the body of the car and wire + at the wire positive of little position lamp...The wire of the position lamp (with other wire) is under the Main box lamps....
With actual distronic you can not mount the illuminated star , but with the next distronic (the radar will be not in the star ) you will be able to mount))
This Wire start from the Main connector under the box lights.Than the black cable with the wire white&violet come upper the lamps. It's easy with your hand to send the way of the Main black cable. than Gently with a Cutter CUT the black strip of the cable and isolated the wire white & violet to take the + for the star.......i hope you understand my italian-english!!!!
Is it so simple that we just connect the +ve of Illuminated star to one wire in the car and -ve wire to another?
The negative wire of the star must be connected at a screw at the body of the car.....you can see in the pictures two negative wire fixed at a screw.....
Can i please request you to highlight (in my attached pic) the area where i can find the part shown in pic 9 and 10?
