Too stiff ride on ML 350, 2013. Oh my God
Old Jul 9, 2014 | 02:43 PM
Taleh's Avatar
Too stiff ride on my ML 350, 2013. suspension is base, non-airmatic. i need extremely comfortable ride, handling is not interesting to me at all. i live in bulgaria, the roads here are damn so bad...
the car came with 18 inch original european wheels, michelin non run flat tires. still the suspension is too stiff for me. i even tried airmatic version, it is even stiffer than base suspension. what else can i do? is there a chance to tweak the suspension anyhow by change the suspension springs or other parts names of which i technically do not recall?
thank you for any kind of help.
Old Jul 9, 2014 | 04:55 PM
DFW01E55's Avatar
'14 ML BT
Good luck Taleh, the ride seems really soft to me.
Don't bother trying the Lincoln MKX then (if it's available there). It's a feature packed car, but the ride quality is slightly harsher than the ML.
Old Jul 9, 2014 | 08:33 PM
Nanook's Avatar
'18 GLE63S AMG /'19 PORSCHE TURBO S / '09 CORVETTE ZR1 /'14 LEXUS RX350/'16 RAV4 Ltd
A start would be 17" wheels
Old Jul 10, 2014 | 12:59 AM
mellow sparky's Avatar
ML350
I was going to say "a start would be a Mercedes Benz" ... oops
Old Jul 10, 2014 | 12:14 PM
2012MLBlue's Avatar
2016 GLE 350d
Get rid of the run flat tires.
Old Jul 10, 2014 | 04:19 PM
frtdog's Avatar
2020 GLE 450
I'm afraid with the steel springs there will not be much you can do. Some here might be able to recommend a wheel/tire combination that might soften the ride a bit but probably not much.
Good luck.
Old Jul 10, 2014 | 06:47 PM
Baloo588's Avatar
What tire pressures are you running? I hope they are not the mercedes max load pressures. They should be at 33-34 cold psi. Sometimes dealers over inflate the tires on the MLs when in transport to prevent flat spots.
The ML350 is so smooth over the worse pot hole ridden roads we have in Michigan during the winter time. I love how it soaks them up with ease even with 4matic that it feels refined as the S-class.I got michelin all season latitude tour Hp tires and use 34 psi cold. Are you with summer tires? They will cause stiff ride regardless of pressure,
Old Jul 10, 2014 | 06:57 PM
Need4Speed's Avatar
Former Vendor of MBWorld
2018 C63S
The run flats will make the ride harsher
Old Jul 10, 2014 | 10:51 PM
fabbrisd1's Avatar
A gaggle of MB's
You will NEVER get any type of ride at all in Bulgaria with Run Flats - the nature of the run flat is there are aluminum discs that replace sidewalls of a conventional a conventional tire - so it's like riding on a chariot/wheel around a Roman arena - aweful !
Old Jul 11, 2014 | 01:24 AM
27T's Avatar
27T
13ML BT
I think he said he does NOT have runflats.
Best advice is look for 15" rims and add bubble tires.
Old Jul 11, 2014 | 01:34 AM
screw991le's Avatar
2010 E63 AMG
Run flats are the worst. Had them on a Corvette. I felt like the Flintstones.
Old Jul 11, 2014 | 06:05 AM
GregGebhardt's Avatar
2014 ML350 BlueTec
The OP said: "michelin non run flat tires"
Old Jul 11, 2014 | 06:06 AM
2014 ML350 BlueTec
See my post above
Old Jul 11, 2014 | 08:50 AM
Shrdlu's Avatar
2018 GLE 43 SUV
He says he has "michelin non run flat tires," so it seems unclear whether he has them or not.
Old Aug 12, 2014 | 12:18 AM
galion's Avatar
2013 C63
Huh? My ML350 with base suspension and 20"s is the most comfortable ride car Id ever driven.
Old Aug 12, 2014 | 02:01 AM
jtorrebl's Avatar
2025 Panamera GTS
Don't buy an SUV
Old Aug 12, 2014 | 04:56 AM
2014 ML350 BlueTec
Worst is I HAVE the Perelli run flats and am VERY happy with the ride on my 2014 350BT. I am not unhappy with this sacrifice for the B&O audio. I have a plug kit and air pump to make me feel better but have to face the fact that I have not had a flat in my last three vehicles.
Everyone's perception of what is a good "ride" is different.
