planning to drop my ml350 pls help
hi! i am thinking of lowering my 2013 ml350 with 20" wheels. i just want to know how bad the ride will be if i change my springs to H&R. will drop approximately 1.6" rear and 1.8" in the front. if it won't change my ride that much i will go for it. pls reply your advice. thanks
Ml350 bt
According to specs, you only have little more than 5 inches of ground clearance as it is, why lower it further? You might end up scraping The underside at parking garage ramps and speed bumps.
ml350 bluetec
Why would you want to drop your ML. That reminds me of a Pagini Zonda and a Mazerati, racing past me last summer, leaving a trail of scuff marks, sparks and bits & pieces and some parts. I don't care who won or lost, I just laughed at the stupidity of it all.
'18 GLE63S AMG /'19 PORSCHE TURBO S / '09 CORVETTE ZR1 /'14 LEXUS RX350/'16 RAV4 Ltd
I lowered my ML63 about 1.5" with links..it firmed up handling and looks much better with less space over the tires...
And if I need extra clearance I just push the raise button.
The links are easily removed or adjusted although I never have done either...I may lower another .5" this summer.. we'll see
https://mbworld.org/forums/new-m-cla...mmed-pics.html
1 Post
2013 ML 550, CLK63 AMG, 2012 E350 4MATIC
sounds fantastic, do a search for dropped ML you'll see examples. hellaflush too, look good on the street.
