''Auxiliary battery malfunction''
Hi MB fans,
I got that message this morning while I was starting to drive like Hamilton with my ml63 and switching from Confort to S+
The message: ''Auxiliary battery malfunction'' apperared when I pressed the suspension switch...
What is it exactly?
Thanks so much in advance.
What is it exactly?
1 Post
ML350 BT soon......pleeeease. GOT IT NOW....Wooooo
Auxiliary battery probably has low voltage or the control device that connects it may be faulty.
Electrical items like power windows etc run off the rear battery.
'18 GLE63S AMG /'19 PORSCHE TURBO S / '09 CORVETTE ZR1 /'14 LEXUS RX350/'16 RAV4 Ltd
Evo would you know the location of this battery ? I know the main is under the passenger seat but I'm curious where this unit is located..
You can drive normally without the aux battery. Mine went out in Jan and I drove for a week before I had time to take it to the dealer. Battery had shorted out and was replaced under warranty.
Not sure exactly what the aux battery is used for but all functions worked normally (windows, etc.)
1 Post
If the main battery voltage drops below a set figure, the battery control module connects the auxiliary battery to make sure engine crank over for start......aux bat not normally connected for starting.
