A couple important hints
Old Nov 7, 2015 | 07:25 PM
Nanook's Avatar
'18 GLE63S AMG /'19 PORSCHE TURBO S / '09 CORVETTE ZR1 /'14 LEXUS RX350/'16 RAV4 Ltd
I just did my winter tire swap and here are a couple tips for you keeners
1) NEVER use the fancy dancy MB (or other) metal valve stem caps..you'll look real cool until you have to remove them to adjust tire pressure...the metal welds itself to the valve stem and this is what you get...either a stripped stem or the end snaps off..
2) THIS idea is a real back saver...an absolute must for these heavy 21/20 inch wheels that use studs rather than lug nuts..ebay and you really only need one
Old Nov 7, 2015 | 07:39 PM
Barry45RPM's Avatar
2015 ML 350
Yup... Wheels with TPMS have metal stems not the rubber ones and the 2 metals do corrode together. That's why they come with plastic stem caps that have been painted silver.
Old Nov 8, 2015 | 03:34 PM
racer12's Avatar
2014 ML 350 2003 Clk 430 2009 C300
Can you please post the link for the studs.I looked on Ebay with no luck
Old Nov 8, 2015 | 05:13 PM
Nanook's Avatar
Make sure you get the right one for your application
http://www.ebay.com/itm/2PCS-Mercede...371466&vxp=mtr
Old Nov 8, 2015 | 05:45 PM
racer12's Avatar
Thanks ever so much
Dan
Old Nov 8, 2015 | 05:51 PM
Nanook's Avatar
My pleasure cheers
Old Nov 8, 2015 | 07:44 PM
racer12's Avatar
I ordered a set and free shipping to my house in Fla.
Old Nov 8, 2015 | 08:02 PM
Keyser Soze's Avatar
2010 GL450 and 2016 GLE350
Save your money.........A 'wheel alignment bolt' is in the spare wheel compartment. From the Operating Manual wheel changing page:
X Slide the wheel to be mounted onto the alignment bolt and push it on.
X Tighten the wheel bolts until they are fingertight.
X Unscrew the alignment bolt.
Old Nov 8, 2015 | 08:42 PM
Nanook's Avatar
Hmm..no such accessory in my kit..either it didn't come with or previous owner did away with it..
Old Nov 8, 2015 | 08:50 PM
racer12's Avatar
Nor mine
Old Nov 9, 2015 | 01:07 AM
jtorrebl's Avatar
2025 Panamera GTS
It should've been in there
Old Nov 9, 2015 | 08:21 AM
racer12's Avatar
The Canadian cars seem to have different stuff in them than US cars. Also the previous clown who owned the car that I have to sell because of smoker who owned it took the first aid kit.
Old Nov 10, 2015 | 02:31 PM
shotgun_banjo's Avatar
'13 GLK350 4matic,'10 C207,'15 GLA250,'07 Honda Odyssey, '18 GLE 43, '24 EQS 580
My Canadian ML has the wheel alignment bolt.
Old Nov 10, 2015 | 02:33 PM
Nanook,
How come you have TPMS on your ML? I thought all MB cars here in Canada does not have TPMS on the wheels?
