Auto dip mirror on revers?
W166 ML
I wonder if anyone has got this working.
I was reading in the manual that you can get the mirrors to dip down so you can see the kerb when you engage reverse. Has anyone got this to work?
I don't have the memory pack. However, the manual says it's not required.
you just need to put your shift to reverse (with Key in position 2), and select the right mirror, then adjust the mirror to the position you want. That's how I set mine... but, not sure this will work without memory seats.
If you move your shift out of reverse, the mirror will return to its original position in a 2-3 sec later.
