W166 Keyless go module location?
Hi all,
Does anyone know the exact location of the keyless go module on a 2013 ML350 V6 N/A? I'm in the middle of installing my remote starter and need to modify the CANH and CANL wires before I can start programming the remote starter. I did a quick search and one person mentioned the antenna is under the center console, can anyone confirm if this is the correct location for the module before I start pulling it a part? Thank you.
There is an antenna under the console, but the antenna is not the module that has the connections you are after. The KG module is under the left side of the rear seat. You have to remove your rear seat and pull up the carpet to get to the module.
peter2772000 (12-19-2018)
look at mid city engineering website under w166 manuals and instructions, they have step by step instructions with pics.
the k/g module on mine 2012 ml350 is under l/r seat
