W166-How to remove the annoying pin on the front wheel low beam housing door ?
Old Oct 28, 2021 | 09:55 AM
c3002008's Avatar
C300, ML350
I tried it all..
screwdrivers, trim puller tool but none of it worked to get that annoying pin off. I only managed to pry it up just a little but the dang thing doesn’t want to come off and didn’t want to break anything. Any suggestions.
can someone provide me with the part number for these pins?Going to put more force and if that doesn’t work I will just break it off with some vise grips.
update—- couldn’t get it off, got it off almost halfway but doesn’t pull off . And I didn’t want to break it.
I will buy these 2 step panel pliers and will hope it works.
https://www.harborfreight.com/panel-...ers-63699.html
Old Oct 28, 2021 | 09:12 PM
expl0rer's Avatar
GL550 X164
Check out this YouTube video.
Old Oct 28, 2021 | 09:13 PM
E55Greasemonkey's Avatar
This place is a joke.
The center rivet has to be removed completely before thr main rivet is pulled out.
Old Oct 28, 2021 | 09:18 PM
c3002008's Avatar
C300, ML350
mine doesn’t have a center rivet , it’s just one head. Maybe it’s an aftermarket one? I will buy those special pliers from Harbor Freight this weekend and hope that works.
Old Oct 28, 2021 | 09:21 PM
c3002008's Avatar
C300, ML350
https://youtu.be/mZuTyPvg8CM
thanks… but I’d rather do it the proper way by removing the front wheel fender door so that way I will have more clearance when installing the bulbs.
Old Nov 25, 2021 | 10:52 PM
Issac2021's Avatar
ML350
It's very easy. I used the tool from Amazon.
Amazon Amazon
The metal one.
Today I installed the LED lights including low beam and high beam from Lasfit( 20% off for Thanksgiving). They look much better than Halogen lights.
Old Nov 25, 2021 | 11:00 PM
Issac2021's Avatar
ML350
The low beam cover of this video broken.
