Keyless Go problem and fix
Recently, my keyless go fonction stopped working on my ML350 2012 W166. To be precise, the lock/unlock via the door handles and the push to start button stopped working completely. However the button to unlock/lock the doors on the key were still working and I was able to start the car when inserting the key in the ignition with the cover removed.
I tried all the usual troubleshooting, replacing the batteries of the keys, checking all fuses, removing them to reset modules, etc...
Finally the solution was to replace the control module located under the back seat with a used module found on eBay. I can confirm that no reprogramming were necessary, I simply swapped the module and everything started to work as it should!
To access the module, you are supposed to remove the back of the seat to lift the carpet. I decided it was not worth the trouble and simply cut a hole. This is always hidden by the seat anyway.
Here some picture of the hole I made and the control module:
Section cut with exacto under the back seat
The white module can be seen at the bottom of the picture. You can make a smaller hole, if you get closer to the door it will make things easier.
My old module
Your experience may be different than mine but I was really happy this 10 minutes fix brought back this great feature to my car 😁
My old module
Also, that side of the rear seat is really heavy, I hate to try and lift it out. Its hard enough just to push it up into the upright position.
My old module
