Cam adjuster alignment
Old Yesterday | 02:54 PM
Mariner1's Avatar
2012 ML350, 2010 Camaro 2SS, 1998 BMW M3 vert, 1985 BMW 5 Series with Procharged SBC
I made a more detailed post on timing and reassembling my M276.9 earlier today but I have a more specific question so I'm making a new thread.
At 53 deg after TDC ignition, all four reluctor wheels line up perfectly in their respective CPS holes
On Bank 1, at 40 deg after TDC overlap, the laser mark (highlighted in yellow in the pic) on the INTAKE cam adjuster is exactly one tooth below the left hand bolt hole for the chain tensioner. The laser mark for the EXHAUST cam adjuster is exactly one tooth above it.
The WIS picture I have is vague. It's not a straight ahead picture so precisely where the laser marks should point is not clear.
I'm certain the reluctor wheel on the INTAKE cam is in the correct position since I compared it to a known good cam, so the INTAKE laser mark should be in the correct position.
Since the EXHAUST cam does not have laser marks on the reluctor wheel or the cam hub, I can't be sure the reluctor wheel hasn't moved or that the laser mark on the EXHAUST cam adjuster is pointing in the correct position.
Is it?
Advice greatly appreciated.
Thanks...Mariner1
Old Today | 03:02 AM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
timing marks alignment
The marks on the VVT gears reference alignment with the TENSIONERS being installed.
Not having tensioner installed adds a bit more chain slack to skew cam positions, like 1/2 tooth.
The best part is your relluctors are all in agreement.
So now 99% chance you can confirm VVT marks by looking from the front (not from the top side).
FYI: Loook at your new tensioner backing surface... do you see rough machining marks ?
Send sealing surface smooth with 1,000 grit
E260L in Mainland CN.
260L it is !
260L local market
