Any ideas what can cause ignition timing retard? w210 amg E55
Hello everyone. I have very strange problem with my car. Something is telling my ecu to retard timing even when the car is at idle.
The car has no fault codes in memory. Here are my engine data readings. MAF at WOT - 950kg/h Ignition advance at WOT 19-20* Ignition advance at idle 7-9* I checked the ignition advance of few other cars with same engine and all of them show Ingition advance at WOT 27-29* ignition advance at idle - 14-15* |
Check ur dtcs.. Might either be a faulty IAT sensor or Knock Sensor.. Those usually keep the vehicle on the low octane tables just to be sure..
Originally Posted by Mep_q8
(Post 5978051)
Ditto . |
