Turbo Wheel Upgrades for 04 S600
1 Post
S600 Eurocharged
Anyone making them with proven results.... would like to see what these monsters will make holding 16-17PSI with a bumped redline.
I don't think the manifolds are the big issue here, these turbos just cant supply enough air.
You'd be surprised just how much of a restriction those manifolds actually are.
1 Post
S600 Eurocharged
all we need to do is get some turbos that can hold decent boost to a bumped up redline and these babies will run with the newer exotics, dont believe you need to spend 15k to do this, we have enough injector, we have upgraded ecus for fuel and redline, all we need is the turbos, hopefully someone can do just a wheel upgrade, this should cost no more than 1k per side from a respected turbo shop, 1-2k for the ecu and maybe some extra cooling for extended runs at 16-17psi.
uzzle7 (03-15-2024)
Marcin at Speeddriven has supplied me with my ECU and TCU with great results. I will build an sl65 with his upgrades someday. Great guy and I trust him. Call him to talk if you have questions he is a wizzard with the V12 TT platforms.
From what I remember he upgraded someones sl to use bigger turbos but since the stockers are part of the manifold he had to make new ones and put an oil sump with remote pumps...so the ol swap the turbo easily wasnt so easy. To solve this problem he redesigned the turbine and machined the turbine housings to "flow more than the black series turbos" I was planning on doing the upgrade but decided to wait and get an SL or a newer cl or s. The new body style has yet to set in for me. I can say however that I would probably purchase an s just because the CL and S look so darn similar... 2 free doors and seats. The old CL lowered and on 20's still hits a sweet spot for me.
Actually you barely have enough injector for a bigger turbo. Your car with a tune should be right around the 15psi range with just a tune. A compressor wheel upgrade gets you up to more along the line of about 20psi but other problems start to surface if boost is pushed beyond that. Turbine wheel is done by kkk (now borg warner) and they have a NDA with benz so you can't get a new shaft, wheel, or even seals for that matter. So everything becomes custom. Custom means big $$. And keep in mind that even when I go to a machine shop or a turbo shop when they see the benz logo I get hit with the benz tax before the part even gets made.
Question that you really need to ask yourself is how much are you willing to pay for labor to pull your motor and have a compressor wheel swap done for about 40-50whp?
1 Post
S600 Eurocharged
uzzle7 (03-15-2024)
1 Post
S600 Eurocharged
Hmmm, used to have meth on my vr4 worked out ok, really dont wanna risk this v12 though even though there are some smart people out there that can tune it properly. though interested to know what intercooler/HE gives power gains, i would say a budget of 5k....
1 Post
S600 Eurocharged
Awesome numbers guys.... although the Sl600 might trap a couple of mph higher than my s600 with just a tune, i mean after all it is ~300lbs lighter or so.
JayCL600 did a full 3 inch with high flow cats, if I recall it netted him somewhere in the 30-40rwhp range. Not to mention a lighter exhaust. I have 2 stock IC cores for sale cheap if you want to go a la quad (brabus)
