M275 Engine redesign and build custom car
Hi I have a spare m275 complete engine with turbos.
I have decided to build a 1 off car making my own spaceframe, hubs, suspension components and arms.
I am planing to mid mount the engine and use a Ferrari manual gear box. for a rear wheel drive setup
I was thinking of using a big block flywheel and clutch pack. I would only have to drill 1 hole in the fly wheel for fitting.
I understand I would need a custom bell housing.
I am open to any ideas on a manual transmission set up for a rear wheel drive set up?
On to the M275
I want to remove the coil packs and fit individual packs.
custom exhaust manifolds
Custom turbos
750cc Injectors
Remove water cooled intercoolers and run 2 x intercoolers mounted in the rear quarters with loads of venting.
Oil cooler
gearbox cooler
remove the vacuum box and all the vacuum lines and valves
2 x external wast-gates
Big radiator and twin electric fans.
Another thought would be water-less coolant.
I want to modify the front left camshaft plate by removing the EGR's and the thermostat housing so the exhaust gas do not go into it.
Also I am removing the alternator water coolant idea and welding a plate over the block and making a bracket to hold the new alternator that will help with cooiling. Also I will be removing the rear climate pump and maybe the A/C
Any Input and Ideas welcomed
On to the M275
Custom turbos
750cc Injectors
Oil cooler
gearbox cooler
Sounds like a cheap project.
I had the same thoughts using a carbon gt40 replica tub as the base.
My advice would be try and get as much info on the new Pagani as they have already done it.
