Oil seeping from lower oil pan gasket
Recently noticed a few oil drops on the garage floor, so put it up on a lift and see "damp" areas around the lower oil pan gasket. It's a 13-year old motor with 68,000 miles. I had recently changed the oil and filled with Mobil 1 0W-40 vs. 5W-40 from last fill. Would this change in oil grade cause seeping to begin, or is it simply age catching up to me?
I very much doubt it's anything to do with the oil grade.
There are lots of place oil can leak - are you sure it's the lower sump? If it is, it's a relatively easy fix. Nick |
Originally Posted by Welwynnick
(Post 7339561)
...are you sure it's the lower sump? If it is, it's a relatively easy fix.
