Unusually Cold Weather cause ABC leaks?
My <40k W221 S600 is normally stored inside, and has been driven <1,000 miles over the past year. For complex reasons, the place where it is stored needed additional room made temporarily, so I had to park it outside for a short period of time, not expecting the frigid 3˚F nights we have been having. Without starting the engine, hydraulic oil was noticed pooling underneath the vehicle. After starting the engine, I noticed in front of the of the radiator on the driver's side a drop of fluid that would drop about every second, so it has clearly sprung a leak. I have not examined underneath the car yet to see exactly the source of the leak, but is there any possibility the cold weather could have anything to do with it? It wasn't even driven any distance when placed outside for a few nights - only a few feet. It has not started sagging or displayed any MIL.
Thanks!
Thanks!
I just replaced my coolant turbo seals...I think temp does affect those. Last year when I put my car away I noticed a small coolant puddle....never found the leak.....never came back until this winter it was much larger.....and found coolant coming from DS turbos
So interesting enough, I now have some leaks in ABC after sitting and colder than normal weather.......last year I replaced a shock and front line to the passenger side shock when I noticed some leaks while sitting......seeing leaking from the 2 high pressure lines that come off the pump.....thoughts?
My car has actually been sitting since I posted the original post. I was able to get a better view of the leak, but need to do some disassembly to get to it better which I hope to get to this week. This is what coincided with the very cold temperatures it was left out overnight in, and only for two or three.
Please take a look and see what you think:
Did the pulsation damper crack?
I will be able to tell much more as soon as I remove the air filter, IC, and coil pack. From what I read, that is all that has to be removed to remove the accumulator.
I noticed in your list of cars that you list a 1992 ZR-1. I also owned a 1992 ZR-1, VIN #32, Black/Tan. Blast to drive!
Randy
It has been a very busy summer and the S600 has been hibernating. The leak is easer to see in this photo. It is below the braided like with the black plastic fastener with the hold for a clip to insert through. I have not spent much time in EPC get a part number yet. Is this a fairly straight forward fix? The color of the hydraulic fluid leads me to believe is has had water contamination.
