M275 V12 Bi-Turbo Platform Technical discussion relating to models sharing the M275 V12 Bi-Turbo (V12 TT). Including SL600, SL65 AMG, CL600, CL65 AMG, S600, S65 AMG.
Mysterious noises M275 AMG SL65
Old 06-24-2018, 02:39 AM
SL65
Recently purchased this car knowing it had this rattling sound. Only noticeably audible from inside the cabin when warmed up and idling at low rpm. Noise goes away if I hold the throttle and raise rpm even slightly; noise goes away once I'm driving forward/backward (basically above idling RPM). Nothing changes whether I'm in neutral or reverse or drive; nothing changes whether I control the fan blower direction, temperature, or AC. I've noticed at night time (colder temperature), the noise appears a lot later (after a longer warm drive), and also sounds quieter compared to a sunny warm afternoon. If I shut off the car for 10min or so, I can startup with a chance the noise not being present, but would shortly appear again after it warms back up.
2 videos, inside and outside. Inside is very obvious. Outside not so much, even if under the car or inside engine bay.
Inside:
https://drive.google.com/file/d/1PxY...ew?usp=sharing
Outside:
https://drive.google.com/file/d/1AVb...ew?usp=sharing
I am clueless, anyone have any ideas?
decadecivic is offline
Old 06-24-2018, 04:19 AM
Ford Mondeo
Welcome to the forums.
Good videos.
I would have a look at the clamping bands that hold the exhaust to the turbos.
After that check the exhaust mounting brackets.
After that the heat shield mountings - there are lots of them.
Are there any faults reported or other symptoms observed? Do you have access to SDS or an OBD2 reader?
Nick
Welwynnick is offline
The Following User Says Thank You to Welwynnick For This Useful Post:
biker349 (06-24-2018)
Old 06-24-2018, 12:14 PM
SL65
Okay, I'll check all those 3 things very soon. Thanks for the direction. The only fault I have right now is relating to my Secondary Air Injection. I doubt that is related to this noise though. I have an Autel MOT Pro to pull codes and read live data if needed.
Good videos.
Nick
Old 07-15-2018, 03:25 PM
SL65
I got the car on a hoist and started inspecting the sound. I used a long screwdriver against my ear as a stethoscope. I've noticed that if I listened against the underside chassis driver side, the knocking sound would be more obvious than on the passenger side.
When I listened on this particular heat shield, I can isolate the noise. Moving or flexing the heat shield did not make the sound go away or any quieter.
When I listened on the heat shield that surrounds the steering shaft, it is the loudest and most obvious. I noticed that it was much more loose compared to the other heat shields, but moving it around didn't make the sound go away either.
Everything else I listened to, such as the cat converter, turbo, manifold, transmission, motor mounts, does not create or transfer that knocking sound. I am really confused as to why this noise would occur only when the car hot, and only at idling rpm. It seems like the noise is coming from the driver side firewall. I'm trying to look at component diagrams of the car and figure out if there are any motors, solenoids, etc, that exist at the driver side firewall, that maybe, once hot, would produce that sound. The most obvious source of the sound was when I listened to that heat shield surrounding the steering shaft.
Old 07-20-2018, 12:27 PM
SL65
bump. Anyone have any inputs?
Old 07-21-2018, 12:55 AM
AmgSeahawker's Avatar
08 clk63, 06 E55, 05 c55, 14 ml350, 98 pathfinder. Have owned cl55, s55, cls55, c230, cl500, cls500
Did you listen to ABC pump, a/c compressor or alternator? Try removing the engine belt and see if noise is still there
AmgSeahawker is offline
Old 07-22-2018, 01:12 AM
2005 S55 AMG
Change the pulsation dampener
g60wall is offline
Old 07-22-2018, 01:13 AM
2005 S55 AMG
Have you done motor mounts?
g60wall is offline
Old 07-24-2018, 09:22 PM
SL65
Yup, I probed those and the clicking wasn't from there. Like I mentioned, it was most prominent and obvious when I probed the chassis, front driver area. I could try and remove the accessory belt and run it, but will it be an issue on these Mercedes if I start & run the car without the alternator running?
Old 07-24-2018, 09:31 PM
SL65
I've recently purchased the car, not sure if they've been recently replaced prior. I did probe both engine mounts and they don't create or transmit the sound.
Old 08-22-2018, 04:02 PM
2013 W204 C63 AMG, 2008 W221 S65 AMG
Does the noise change with accessory loads or if the AC is loaded/unloaded? This noise sounds like a damper in the AC pulley or the ABC pump itself.
alexanderfoti is offline
Old 09-07-2018, 01:16 AM
SL65
No it doesn't. The only thing that affects whether the noise appears or not is if the rpm is low enough, idling, and if the car is warmed up. Also like I mentioned, I did probe the area near the driver side firewall, and the steering column heat shroud is the point where the knocking sound is the most clearest through the stethoscope.
Old 09-08-2018, 10:45 PM
driveability's Avatar
Cl65 AMG
since you own the car now maybe contact the PO and ask him to come clean on anything he may know concerning the noise. I would get a cheep HF stethoscope and isolate the noise. You will be able to narrow down the area. Without the scope there's just too much coming at you.
driveability is offline
Old 02-01-2019, 01:54 AM
SL65
To this day, still have not figured it out. The source of the sound is somewhere in the firewall area, underneath the windshield wiper unit. At this point, I'm guessing it is something loose that only vibrates when the car is fully warmed up and is allowed to warm idle at 500-600rpm. The noise gets annoying. I'm looking at potentially raising the warm idle rpm to maybe 600-800rpm just to make the noise go away. I know this would work because as I've mentioned before, I hold throttle a tiny amount so it cold idles at ~800rpm, rattle goes away. As well, when the car is still cold and the idle rpm is above 750rpm dash line, noise is not present.
Does anyone know if a Mercedes das/star xentry (im not familiar with these OEM softwares/tools) has the ability to adjust the warm idle rpm and raise it?
If someone can confirm it's not possible to do that, then the only other method I can think of to adjust the rpm is to 'trick' the ECU by modding the coolant temperature sensor. I could raise the warm idle rpm is by adding a resistor rated somewhere between 30Ohm-150Ohm in the wiring connector to the coolant temperature sensor. I have previously worked on other cars and used this method to 'trick' the coolant temp in order to adjust the warm idle rpm this way. I'm not sure how these Mercedes' ECU works entirely, but I know most cars have a proportional relationship between coolant temps and idle rpm. If these Mercedes works in the same principle, then I should be able to trick the ECU into thinking the coolant temps are at 80C and keep the idle rpm in the 700rpm range.
Old 02-07-2019, 05:20 PM
syljua's Avatar
1998 C140 CL500
No, warm it up until the noise appears, and then remove the belt.The car can work for some time with spark power just powered from the battery. But, I would not let it run for too long, because of the water pump(s?).
br,
syljua
syljua is offline
Old 02-10-2019, 02:39 PM
br,
syljua
Yes, do this. Raising the RPM to remove the sound is not ideal, that noise shouldnt be ignored.
You can raise the idle by 50rpm in STAR.
Quick Reply: Mysterious noises M275 AMG SL65
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Your question will be posted in:
