M275 V12 Bi-Turbo Platform Technical discussion relating to models sharing the M275 V12 Bi-Turbo (V12 TT). Including SL600, SL65 AMG, CL600, CL65 AMG, S600, S65 AMG.
Major loss of horsepower in 05 cl65....
Old Jun 13, 2019 | 11:24 PM
02cl55amg's Avatar
CL65
2005 cl65
eurcharged tuned
intake
full exhaust
trunk tank/pump
car made 660rwhp on dyno with 100 octane
ran 10.9@127
Car has been running like **** for a while and want to get sorted out Ran the car lastnight via dragy app
and trapped 117mph .Been to two Independent shops with no luck. car has no CEL or stored codes and runs fine until you get on it. struggles to get over 100mph.
checked all vacuum lines and sensors all appear to be good. compression check ok, fresh spark plugs and boost solenoid. I even sent ecu back to jerry and he said all was good.
ive logged iat's and they're under 140deg on all runs. Also have logged boost and hits 20psi@ full throttle and tapers off to 15psi. boost seems off as I remember years ago seeing about 25psi on hit and tapering to ,18. Not sure where else to check or what could possibly be wrong. any and all help greatly appreciated.
Old Aug 12, 2020 | 05:12 AM
pmercury's Avatar
member
CL
Originally Posted by 02cl55amg
2005 cl65
eurcharged tuned
intake
full exhaust
trunk tank/pump
ran 10.9@127
my boost on a CL600 with stock turbos
https://mbworld.org/forums/m275-v12-...hanol-kit.html
I hit 9.7@127 before the Methanol already
after methanol 34 psi
gonna run a new measurement these days when the weather allows it
you need at least better radiator, pusher fans, 2 pierburg pumps, a kleeman tune, methanol injection, suspension tune and a LSD differential of course
my car is so fast now , it behaves as a 200 pounds go-kart
Old Aug 12, 2020 | 05:22 AM
pmercury's Avatar
member
CL
people don't understand this engine, the major secret for power = COOLING
