Sydney W220 Airmatic & front suspension for sale
Steering/Suspension
  • Expired
    $4,000
    • OBO
  • Location Sydney, Australia
  • Compatibility
Make Model Year
Mercedes-Benz S430 1998 - 2006
Mercedes-Benz S320 1998 - 2003
Mercedes-Benz S350 2003 - 2006
Mercedes-Benz S500 1998 - 2006
Mercedes-Benz S500L 1998 - 2006
I own a W220 S Class and 9 months & 5,983 kms ago had all four air shocks, all six control arms in the front end along with the inner and outer tie rods replaced. New Bistein shocks, Lemforder control arms and Lemforder/Febi tie rods fitted.
The change in the quality of the ride has been quite substantial as I'm sure you could imagine but the amount of driving I do has reduced significantly and the car has developed some other issues so I'm looking to trade it in. The trade-in amounts I've been offered have been very low and when I tell them all the suspension work that's been done the amount doesn't change.
So what I'm thinking is that someone who also owns a W220 (non ABC of course) would appreciate the suspension work and particularly the ability to "test drive" the end result of such work in order to see how much better it is than their current suspension. We could agree on a price for the "new" gear in my car then swap the suspension components between cars. I've still got all the old gear out of my car, so if a particular control arm or shock in your car is really worn I can get my old one put in.
I'm in Sydney, so if you want to find out how nice your W220 ride could be PM me and we can meet up for a drive.
Here is the complete list of what has been replaced:Item
Mercedes #Replacement BrandReplacement #Front shocks
220 330 2438
Bilstein
44-042295
Rear shocks
220 330 5013
Bilstein
44-042301
Front upper control arm [CA] left
220 330 9307
Lemforder
2099202
Front upper CA right
220 330 9407
Lemforder
2099302
Front lower CA left
220 330 8907
Lemforder
3442101
Front lower CA right
220 330 9007
Lemforder
3442201
Front lower forward CA/castor arm/camber strut left
220 330 5711
Lemforder
3123501
Above for right
220 330 5811
Lemforder
3123601
Tie rod inner x 2
230 338 0015
Lemforder
2115302
Tie rod outer x 2
230 330 0403
Febi Bilstein
23087
Note: the two ball joints that the lower CA connects to in the wheel knuckle (Merc # 211 330 0435) were also replaced so every item in the front end has been replaced. But seeing as these are pressed into the knuckle you'll need to buy new ones for the swap. The good part is for the "test drive" you know everything has been replaced.
