Motive Products Black Label European Power Bleeder Kit Available At Pelican Parts!
Old Jun 9, 2015 | 04:23 PM
PelicanParts.com's Avatar
SPONSOR
Brought To You By Pelican Parts!
This innovative brake bleeding device utilizes a hand pump to pressurize the brake fluid system for an easy one-person operation. A small gauge on the front of the brake fluid reservoir indicates pressure. The very large reservoir can hold about two quarts of brake fluid - more than enough for most brake flushing and bleeding jobs. The bleeder is a very useful and cost-effective tool to have in your collection. A pressure bleeder is much better than a vacuum-style bleeder because it will not cause bubbles to form in your brake lines. All bleeders come with a full 1 year warranty.
Don't forget to check out our Pelican Technical Article on Bleeding Brakes.
BLACK LABEL EUROPEAN POWER BLEEDER - Features a custom-machined aluminum cap and deluxe swivel fitting. Comes with an extra length of high grade poly urethane tubing that won't cloud or crack with exposure to brake fluid. Works on most European cars, including Alfa Romeo, Audi, BMW, Fiat, Mercedes, Peugeot, Porsche, Renault, SAAB, Volkswagen, Volvo, and all other cars with 45mm threaded hydraulic fluid reservoir caps.
All models with 45mm threaded hydraulic fluid reservoir caps.
