MB SUVs, Trucks, Vans, Diesels Vendor Classfieds
:: ECS Tuning :: Valve Cover Gasket Kits For Your W163 ML320 (1998-2003)
Old Jan 14, 2016 | 04:56 PM
ECSTuning's Avatar
Former Vendor of MBWorld
2012 SLS AMG
Click HERE to order or for more information.
Starting At – $74.53*
Everywhere there is a seam on your engine, there is the potential for an oil leak. This is prevented through the use of gaskets and seals.
One such gasket that prevents oil leaks is the valve cover gasket. This gasket is used to seal the gap between the valve cover and the cylinder head, however, since this gasket is made of rubber it has a tendency to become brittle, crack and start to leak due to its constant exposure to heat and engine oil.
The crankcase breather hoses attached to the valve covers commonly become brittle over time and crack while removing them from the valve cover. It is recommended to replace the these hoses while doing a valve cover gasket job.
Now you can replace your failed valve cover gaskets with this kit from ECS Tuning to get the job done right.
Fits:
ML320 (1998-2003)
*Price subject to change.
