w203 command/tv wiring harness, what is this black connector?
Old Mar 5, 2006 | 08:54 AM
perdikoula888's Avatar
Hi everybody I have just installed the full comand wiring harness. However, I do not know what is this black 10 pin connector with 2 blue wires. Where do I connect it to? please help!
Attached Thumbnails w203 command/tv wiring harness, what is this black connector?-connector.jpg
Old Mar 5, 2006 | 06:19 PM
please help!
Old Mar 5, 2006 | 06:23 PM
benzmodz's Avatar
W203 slightly modified
Originally Posted by perdikoula888
please help!
Goes to the right hand side footwell kick panel. is a junction to the fibre optic signal lines to wake up fibre optic.
It is a common point to COMAND, UHI, VCS, stacker and BOSE.
IT is a common joining block for those devices and represents the copper side of the optical signal.
Old Mar 5, 2006 | 06:39 PM
SUNILP's Avatar
2015 E250D
That is the wakeup line for all the fiber optic connected devices. Just like benzmodz said. If your fiber connected items are ever dead, check the wakeup line, fiber loop, and makesure each device is getting power.
Old Mar 5, 2006 | 06:47 PM
Thank you both for the help, will check it in the morning when I go to the garage. Is the block that has to be connected close to the foot kick panel? are there any more wire connected to this blck or is it a dedicated block solely for this 2 wire 10 pin plug?
....Or it stays unconnected just with the loop clip on it?
still learning slowly...
thank you for your patience
Old Mar 5, 2006 | 07:59 PM
benzmodz's Avatar
As stated above. The phone, voice control and bose all going into it as well.
Old Mar 6, 2006 | 04:55 PM
Thank you for making it clear!
