'99 w202 C230 K BAS/ASR Malfunction
Old May 23, 2006 | 03:36 PM
fedie's Avatar
Unhappy '99 w202 C230 K BAS/ASR Malfunction
I was wondering if someone can help me out, a month ago the BAS/ASR light came on, I took the car to my buddys to scan it and I got 2 error codes.
C1025 ABS CAN BUS Signal cannot be transfered
C1022 Fault in CAN comunication with:ME N3/10
it's a 1999 C230 Kompressor.
Thank you
Old May 23, 2006 | 07:33 PM
MBTech21's Avatar
05 ML350, 85 300D
Here is the latest CAN incident...
https://mbworld.org/forums/mercedes-tech-talk/147176-need-help-2000-s-class-can-issue-car-dealer.html
Old Oct 29, 2006 | 09:03 AM
fedie's Avatar
do you guys think this could be related to the brake switch thing?
Old Oct 29, 2006 | 10:35 AM
lkchris's Avatar
'10 CL550, '12 GL550
Test it.
From Mercedes Enthusiast:
Sometimes the ESP and ABS warning lights can come on, but that may be simply a problem with the brake-light switch, as these two functions are wired through it. ... simple test: Start the engine with your foot on the brake. If the Brake Assist light goes out when you release the brake but then comes back on, it's just the brake light switch that is faulty.
Old Oct 29, 2006 | 11:26 AM
fedie's Avatar
WHOOHOO FIXED!!!
https://mbworld.org/forums/showthrea...63#post1813763
Thanks!!
