Hard starting
Old Jul 3, 2008 | 04:20 PM
BrianM's Avatar
1991 500sl
Question Hard starting
My friend has a 1991 500sl with a 5.0L engine
It starts fine cold, but when warm it takes about 30seconds to start. when started it runs ok
Old Jul 5, 2008 | 02:20 AM
Ausmbtech's Avatar
190D 2.5 (x2), 190E 2.6, W202 C240,W202 C43 (C55), W210 E55, W212 E250CDI
If you have a LH fuel injection (electronic injection), not KE injection (big air flap under air filter) then it would most likely be a leaking fuel pressure regulator causing your hard hot start issue.
Old Jul 6, 2008 | 03:53 PM
BrianM's Avatar
1991 500sl
hard starting
Mine has a round flap about 3" under the air filters, is that what you mean by big flap? If so what might it be then?
Brian
Old Jul 7, 2008 | 10:28 AM
Ausmbtech's Avatar
I'd recommend you get someone familiar with Bosch KE injection to carry on with diagnosis for you vehicle due to the relative complexities of the system for someone with limited experience.
I believe it would be fuel pressure related but unlike current fuel injection, educated guessing isn't recommended
Old Jul 13, 2008 | 04:45 PM
benz-tech's Avatar
BMW E30. I've turned to the dark side.
needs a MAF or a crank position sensor........jk. cis-e is no fun, you need to find an old-school tech to look at it. i (in this rare case) would shy away from a dealer.
Old Jul 16, 2008 | 08:21 PM
BrianM's Avatar
1991 500sl
Hard Starting
I will check these out.
I might also mention that when has been running and warm it will start right away right after shutdown. the hard starting is after it sits for 1/2 hour or say up to 2 hours. We have tried releasing the pressure in the gas tank before starting, but no different.
Old Jul 17, 2008 | 08:07 AM
Ausmbtech's Avatar
It'll be a fuel pressure related problem, could be the accumulator next to the fuel pump but, as I said before, it really needs to be diagnosed by someone who knows KE-jetronic very well and who has the appropriate equipment.
