MB Tech Interesting 209 Issue
Old Feb 22, 2003 | 06:42 PM
RJC's Avatar
RJC
Various
Exclamation MB Tech Interesting 209 Issue
Today the weather in FLA hit 85, after a lot of stop and go driving I stopped at draw bridge and after about 5 mins I felt a weird vibration go through the car, I traced it to the cooling fan swithcing to high speed. I noticed that this fan is a new design as there not a normal engine fan and aux. cooling fans only a giant electric fan. After examining the fan I saw there was a small metal clip on one of the blades of the fan I guess it's a balancing weight. Have you encountered this problem and is there a way to balance this out or do I have to go the replacement route?Any TSB issued.
Thanks again,
Old Feb 22, 2003 | 07:00 PM
mbtech208's Avatar
1997 Toyota Tacoma 4x4
I've replaced a handful of S500 cooling fans (same set-up as your car) due to the fan shaft wearing out, causing the fan to wobble and rub on the shroud. But this is the first I've heard of a vibration. I don't know where to lead you on this one, no bulletins issued that I'm aware of. Let me know the outcome.
Old Feb 22, 2003 | 07:56 PM
RJC's Avatar
RJC
Various
I will Dave. Let me know if you hear of anything on Monday at the dealer.
Regards,
Old Feb 23, 2003 | 03:08 PM
patrick's Avatar
RJC,
I already talked to you about a vibrating cooling fan:
Originally posted by patrick
...Last time I had a car that began to vibrate at certain moments. No fault codes memorised, all measured values correct. It turned out to be the fan...
...At a certain speed (fan speed) it started to produce a kind of vibration as if it was coming from the engine that did not turn so well...
If I were you I would not bother, yust go see your dealer and let them replace it. The car is under warranty.
Old Feb 23, 2003 | 09:37 PM
RJC's Avatar
RJC
Various
RJC,
Wasn't that when we were discussing engine miss problems on my 208? Never had a cooling fan issue on that car.
My 209 is only two weeks old and as you know the cooling fan system is of a totally different design...what car/model did you have the fan problem with?
Thanks Pat
