97' E420 Engine noise
Old Jul 20, 2003 | 08:34 PM
kennygss's Avatar
1997 E420
I have a 97' E420 with 55K miles. It has developed a "click" in the valve train. Kind of like a stuck valve aor lifter. It has come and gone a couple of times. Any ideas? Thanks.
Old Jul 20, 2003 | 09:41 PM
f4i 954's Avatar
2009 e class 2012 ml350
lifter noise
Possible the oil feed to one of your lifters fell out, comen on 119 engines.
Old Jul 21, 2003 | 11:37 AM
kennygss's Avatar
1997 E420
Thanks for that. If that is indeed the case, is it a job should tackle? Or is it best left to the pro's?
Old Jul 21, 2003 | 10:45 PM
kennygss's Avatar
1997 E420
Ok, the noise went away! Thats twice it's come and gone. Ideas?
Old Jul 22, 2003 | 09:19 AM
corgiman's Avatar
E55
If the noise is a ticking that typically happens right after you start the car it's probably a lifter that has a leak and collapses while sitting. This is more pronounced when the car is hot or has been setting for a long time. If it ticks a few times and then goes away it's annoying but basically harmless. If it ticks constantly it needs attention.
Old Jul 22, 2003 | 09:50 AM
kennygss's Avatar
1997 E420
Actually, it will come while driving and at operating temp., then go away, maybe the next day.
Old Jul 22, 2003 | 03:21 PM
jimmydagreek's Avatar
2022 CLS450 AMG 4Matic
Mine did the exact same thing and we have discussed this in another thread. It was the lifters that made the noise. It started off doing it every once in a while and then it became constant and a lot louder. My MB mechanic suggested switching to fully synthetic oil like Mobil 1 and adding an additive to clean the lifters that is sold by the MB dealer (you can also find these at Pep Boys). The ticking seemed to quiet for a while and then came back just the same. The final outcome was to replace the lifters. The MB dealer wanted over $3000 bucks for this job but thank God for my mechanic as he only charged me about $1500 bucks and replaced the timing chain and some other items in there in which I don't remember now and included warranty. The car (knock on wood) runs like brand new and better than before I bought it! I continue to use Mobil 1 fully syn. oil now and have not had anymore problems since. Good luck and hopefully you can cure your problem if it's minor with the syn. oil and lifter cleaning additive...
Old Jul 22, 2003 | 05:16 PM
kennygss's Avatar
1997 E420
Thanks for the input fellas! Im gonna try a "top-engine clean" oil additive, then switch from 20-50 Vslvoline to a Synthetic and see whats up then. Hope for the best I guess, but hey, if I need lifters, that would be an excellent time to replace the camshafts with something better and then I could...
Old Jul 22, 2003 | 05:24 PM
If you need a good MB mechanic, let me know (depending where in So. Cal. you are)...Much luck...
Old Jul 22, 2003 | 08:24 PM
Steve Clark's Avatar
C32AMG
WHY
are you using 20W50 viscosity oil?.The higher viscosity may be contributing to your valve train noise.
Old Jul 23, 2003 | 11:34 AM
kennygss's Avatar
1997 E420
Oil Vis
Steve, It was making the noise(intermittently) before the oil change. Tech recommended that Vis due to recent high weather temps.
Old Jul 23, 2003 | 05:48 PM
mbtech208's Avatar
1997 Toyota Tacoma 4x4
A cap popped off one of the camshaft oiler tubes. Not an uncommon problem on the 119 series engine.
Old Jul 23, 2003 | 06:57 PM
kennygss's Avatar
1997 E420
OK, Is that "cap" repair an easy deal to repair?
Old Jul 30, 2003 | 09:53 AM
kennygss's Avatar
1997 E420
update
So, I went to 10W30 conventional oil, along with an oil treatment (risoline i think) drove the car a while, and noise is gone. We shall see.
