W210 320cdi won't start and stuck in park
problem with locking mechanism in shifter. there is a plastic mechanism that releases shifter when brake is pressed. they are plastic and have a tendency to break. many posts and do it yourself about this.
its nothing to do with that,i can power it and it works,and still dont start
Which is it?
Does the batt have +13V. Dash or headlights lighting up doesn't confirm you have sufficient voltage to turn the starter.
Does the steering wheel lock retract when the key is inserted.
Tried a second key.
Undone what you did that broke it and reinstalled the part.
Confirmed independently that you installed the correct part# yet.
If the key turns, does it crank and not start? Not crank?
Tried starting in Neutral?
Manually released the shifter and try starting in N yet?
Got codes?
Key turns and doesnt crank, bat voltage is fine, havent changed any parts, fault just occured, wont start in neutral.seems like there is a live feed missing somewhere but all fuses seem fine
