C23 Heater blows cold air only when stopped
Old Jan 6, 2014 | 01:30 PM
miket0072003's Avatar
2006 C230 Sport
Post C23 Heater blows cold air only when stopped
My wife's 2006 C230 Sport is blowing cold air, but only when stopped. It works fine while moving. I'm thinking it might be air in the coolant system or a blend door issue. Has anyone seen this problem? There hasn't been any work done on the car in a while as far as the coolant system that would cause air in the system.
Old Jan 7, 2014 | 09:29 PM
Ausmbtech's Avatar
190D 2.5 (x2), 190E 2.6, W202 C240,W202 C43 (C55), W210 E55, W212 E250CDI
When it stops working, put it in park and rev to 2500rpm and see if it comes good again. If it does then the heater booster pump has failed (near coolant bottle). It maintains coolant circulation through the heater at low engine speeds so if it doesn't work the heater is weak at low engine rpm.
Old Jan 9, 2014 | 12:04 PM
2006 C230 Sport
Yes, I measured the air temp at idle, it was about 99 degrees F. When revved to 2500 RPM, the temp jumped to 120 degrees F. I ordered the auxiliary water pump, should be in next week. I hope that fixes it. I will post results.
Thanks for the info, Ausmbtech!
Old Jan 13, 2014 | 04:09 PM
2006 C230 Sport
I changed the aux coolant pump this weekend, added new coolant and the heater works fine now at all RPMs.
