Clutch Help
Old Jan 14, 2004 | 09:36 AM
steve1173's Avatar
Slk 230 & CLK500
Clutch Help
Have a 2003 SLK230 6 speed. Clutch pedal slow to come up sometimes. Looked under the dash for carpet or mats causing it & noticed the spring on the pedal is stretched where only the last 2 links stretch when pushing pedal down. Is this normal, asked the dealer while my other MB in for service but they did not know even though I showed a pictre of it because they said they don't service many manual trans but lead tech took the picture to check it out.
Old Jan 15, 2004 | 06:22 AM
bamberger_1's Avatar
'00 S320 W220, '98 A160 W168/ sold in 2005 '86 260 E W124 '90 260E W124
The clutch pedal for most of the MB cars has hydraulic support (not only spring-type). Check the connection and also for leaks around the pedal. If I'm not completely mistaken it is coming from the brakes system.
Old Jan 15, 2004 | 08:15 AM
Lynn's Avatar
The hydraulic system for the clutch is separate from the brakes.
I'm not certain but it sounds like the return spring you mention has been stretched.
