Thermostat electrical connector
Old May 5, 2016 | 05:51 AM
Euler's Avatar
2008 C63, 2008 ML550, 2014 KTM 500 XC W, John Deere 990
I have a 2008 ML 550 that I recently changed the thermostat on. the thermostat housing has a two-wire electrical connector on it. My question is what is it for?
I don't believe it is a coolant temp sensor as the coolant temp sensor is in the back of the engine.
My best guess is a thermostat valve position sensor or some kind of flow sensor.
Old May 5, 2016 | 09:28 AM
Euler's Avatar
So which is it, flow or position?
Old May 5, 2016 | 04:49 PM
Euler's Avatar
Originally Posted by Plutoe
Your three disc thermostat reports to the ECU the coolant temp. It has three positions 40-65-100C therefore it does both--- at the appropriate temp it opens and a flow results---bla bra
Now that wasn't so hard. Thanks. You'll be getting a postcard from Plains.
