check engine light on, need help interpreting these codes
06 SLK350, check engine light is sometimes on, sometimes isn't. When I first checked the codes, I had 5 codes, I cleared them, 2 came back. Here's the 5 I originally got:
P0011- Powertrain ("A" Camshaft Position - Timing Over-Advanced or system performance (Bank 1))
P0271- Powertrain (Cylinder 4 Injector Circuit High)
(these next 3 are the ones that went away/haven't come back since clearing the codes)
P2767- Powertrain (Input/Turbine Speed Sensor B Circuit No Signal)
P2768- Powertrain (Input/Turbine Speed Sensor B Circuit Intermittent)
U3FFF- Network
I'm having trouble making sense of these. Every other time/vehicle, doing a web search with year make/model with corresponding codes has led me to a quick fix. This time it doesn't seem to be as simple. Thank you for your guys' help, it's appreciated.
U3FFF- Network
