Fully manual W124 4Matic?
Old 10-10-2017, 06:34 PM
moroza's Avatar
BMW, Toyota
I'm a mechanic, taking a slow rainy day to research a particular fantasy: a W124 with a fully manual 4Matic system (4Manual?). By this I mean...
0. Manual transmission, which is rare but apparently exists in this combination. What's still unclear is the source of hydraulic pressure for the two t-case clutch packs, if there's a manual transmission (I assume the auto transmission's hydraulic pump also powers the t-case).
1. Manual front driveline engagement, via a lever or a simple switch controlling a solenoid. In other words, no computer control. I'd be ok with it being on/off, the center diff either completely disengaged or fully locked.
2. That said, it'd be nice to have further control over the center diff, again via a lever or switch controlled only by the driver, to allow pavement-friendly AWD. My research shows two AWD modes for the early W124 system, 65/35 and 50/50, but is unclear whether either of them actually locks the center diff or allows limited slipping via the clutch pack. I also wonder if allowing only on/off operation, like an old truck's part-time 4WD with no center diff, would solve the clutch pack wear I keep reading about.
3. Manual rear diff lock.
Can it be done? Has it been done? Would I be better off trying to retrofit a G-wagen transfer case instead? Thanks in advance for links and technical answers, not along the lines of "close the hood and just drive the car."
Quick Reply: Fully manual W124 4Matic?
