Secondary Air Pump - First Steps?
Probably asked a million times, so a thread link would work.
Here's the question:
2002 ML320
140k
check engine light/code : secondary air pump
swapped in a good, used air pump
inspected contacts and vac lines - all good
relay is good
cold engine - air pump is functioning and quiet
warm engine - pump stops running as it should
AFTER 5 MINUTE IDLING AT WARM ENGINE TEMP - throws the same code, light comes back on
What do I check next?
thnx
2002 ML320
140k
relay is good
thnx
There is more to the system than pump and relay------if you have DAS there are questions to be asked of the system to further help define the real problem------see someone with a system
I’m getting the same code, I reset and can drive 10-20 miles before it comes on again. I’m thinking of buying an advanced code reader to diagnose as suggested. Any updates on what you have discovered?
Waiting for my independent tech to do a comprehensive scan.
Might be this coming week.
Will update.
SPONSOR
WWW.BENZNINJA.COM
2002 ML320
140k
relay is good
thnx
2002 ML320
140k
relay is good
thnx
what code ?
