Go Back  MBWorld.org Forums > Technical & Vehicle Assistance Forums > Mercedes Tech Talk
2014 C250 Ambient Temperature Troubleshoot >
Old 05-19-2019, 03:53 PM
2014 C250, 1979 240D
I am reassembling a 2014 C250 after a collision.
The ambient temperature sensor was damaged so I replaced it.
Still the dashboard reading for the temperature reads ---- (dashes), code scanner also says temp sensor not working.
I replaced the sensor with another, same result.
Jumped across the wires to the sensor, no difference
Examined the wires. they look undamaged.
Stripped the wires near the connector,
Green wire, about 2 volts, could that be as designed?
Brown wire, ground, low resistance.
Started checking fuses but some of them cannot be tested without removing them (molded with plastic flash over the test spots)
It seems unlikely that a fuse would deliver low voltage but I don't have any other ideas.
Before I pull out all of the fuses to test them, does anyone know if there is a fuse for that ambient temperature sensor?
Any other idea, are welcome.
Going to check voltage upstream now.
schmidtjts is offline
Old 05-19-2019, 04:49 PM
Testing the voltage as far upstream as possible, moving wires around, no difference in voltage.
Quick Reply: 2014 C250 Ambient Temperature Troubleshoot
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Your question will be posted in:
