W204 High/Low voltage problem
Old Aug 6, 2023 | 04:54 PM
chahoud t's Avatar
C180 2013
(W204 2014) So when I start the car and during my first gear shift from 1st to 2nd (automatic), the HU supply voltage goes to 15V and Supply voltage to 12V after both of them being constant at 14~. During these few seconds the screen and lights flicker with abs warning issue. This only happens once after the car is turned on and during first shift, if I drive for a while and go from 1st to 2nd again nothing happens.Any idea why?
Old Aug 10, 2023 | 05:11 AM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
USE MB SCANNER
Originally Posted by chahoud t
(W204 2014) So
Any idea why?
I don't think there's a problem with these voltages.
Go ahead scan the car to retrieve faults
Old Dec 21, 2024 | 02:52 AM
yhg1234yhg's Avatar
The same Problem
The Same Problem how did you resolve?
Old Dec 21, 2024 | 02:55 AM
chahoud t's Avatar
C180 2013
First replace both front and rear batteries, the main culprit could be the rear battery. I did so about a year ago no problems anymore except for a split second of flickering lights when i first drive , no resolution for this yet.
Old Dec 21, 2024 | 03:30 AM
yhg1234yhg's Avatar
They say to me and is logic to change alternator regulator because battery can not increase voltage more than 12v and in my case the voltage is increasing more than 12v
Old Dec 21, 2024 | 03:32 AM
chahoud t's Avatar
C180 2013
i changed the regulator some time before the batteries. Did not fix the problem.
i believe the problem was the rear battery was dead and the alternator was working higher voltage to compensate it at start. You can know its the rear battery because eco mode will remain yellow on screen. It should be green when you drive and do full brake the car will shutdown as it is supposed to in eco mode.
Old Dec 21, 2024 | 04:55 AM
Voltages from 12.6V to 14.9V are 100% normal!
This does not cause brake faults... it's a separate issue with faulty module.
Use a scanner to retrieve faults.
> Don't believe me... :
Replace batteries + alternator then you'll get no difference: 12.6 to 14.9v.
Old Dec 21, 2024 | 08:09 AM
JettaRed's Avatar
Veteran: Army
And avoid using the ECO Start/Stop. Does very little for gas mileage and lots of harm to the rest of the car.
Old Dec 21, 2024 | 08:10 AM
JettaRed's Avatar
Veteran: Army
They say to me and is logic to change alternator regulator because battery can not increase voltage more than 12v ...
Not true.
