2016 C300 W205) Weird Headlight Issues
Old Oct 31, 2023 | 12:36 PM
C4Rex's Avatar
2016 C300 4Matic
2016 C300 W205
The drivers side front lights are doing weird things. The low beam is intermittent. The daytime running light is not working at all. The turn signal bar is always on when running. Even for a minute or 2 after shutting off the car. It will even come back on without the car running. The turn signal doesn't blink when activated.
There is A LOT of moisture inside the entire unit. Is this the cause of the problem? Do I need to replace the entire assembly?
Thank you.
Old Oct 31, 2023 | 01:33 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
HL killer... humidity
Originally Posted by C4Rex
2016 C300 W205
Thank you.
Good job, you are 100% correct!
Heavy moisture condensation puddled insde the HL at the lowest point where the unprotected electronic module is conveniently located. The unit is powered directly 24/7. It is remotely managed by SAM CAN LIN Bus.
These units need to be coded by a MB specialist. You may be able to rescue the HL and replace only the controller module. Good luck figuring options & part numbers.
Its hard to say how long this repair will last because the root cause is with the defective venting system. It brings in moisture that accumulates into water.
It does not need heavy rain... I've seen this happen with coastal fog as well.
++++ Fix analysis ...
The HL factory defect is caused by internally regulated TEMP being set too low. This causes dew condensation to accumulate water.
Temp needs to be reprogrammed else more destructive condensation will occur. (Remember that repairs are covered by shop warranty).
Old Oct 31, 2023 | 02:09 PM
C4Rex's Avatar
2016 C300 4Matic
Heavy moisture condensation puddled insde the HL at the lowest point where the unprotected electronic module is conveniently located. The unit is powered directly 24/7. It is remotely managed by SAM CANBus.
Thank you.
Sounds wonderful. Can the venting system be modified to fix the defect? Is there an updated replacement assembly that takes care of the problem?
Old Nov 11, 2023 | 05:26 PM
MB_Carti's Avatar
C205 W/ M177
The fix would be to replace the headlight and all modules connected to the headlight (you must replace everything since you're dealing with water contamination). Then you would book an appointment with an MB dealership to have it programmed. The theory is that your headlight is just a plastic box with LEDs and wires. The headlight modules control all the options, commands, and procedures related to lighting.
Old Nov 12, 2023 | 07:41 AM
JettaRed's Avatar
Veteran: Army
Just hope the repair doesn't total the car.
Old Nov 15, 2023 | 03:10 PM
fish tanks
Thank you.
I don't think HELLA wants to let go of this style of moisture collection.
You can try to deal with venting to control moisture penetration. Some venting is necessary to cool internal heat.
The current solution collects moisture until swampy electronic shorts out to drain batteries.
