2024 GLC 300 Mbux system
Old Nov 19, 2023 | 10:29 AM
RA040624's Avatar
GLC
Hi all,
I am new to Mercedes-Benz being that I have just purchased a 2024 GLC 300.
I did purchase the service maintenance program for the 10,000 mile part a and b maintenance schedule.
I am a car guy and I would like to know how to go into the service section on the car and go into the reset mode..
I would like to go into the system to be able to see how it is done.
Second question, I have attached an image of the oil drain plug. I have never used this type before are these reusable and easy to unscrew it appears to be plastic.
Thanks again for any suggestions you might have.
Old Dec 15, 2023 | 10:05 PM
W205C43PFL's Avatar
Originally Posted by GLCmiked
Hi all,
To reset after changing the engine oil completely service (although if you purchased maintenance package your dealership will reset it)
For plastic drain plugs it is always a good idea to replace it with new ones, last you need are leaks. Even if MB states it is resuable. Cheap insurance. MB wasn't always right (ie. sealed for life transmission fluid, NOT).
Old Dec 18, 2023 | 09:15 AM
JettaRed's Avatar
Veteran: Army
...MB wasn't always right (ie. sealed for life transmission fluid, NOT).
Just curious, but when did Mercedes state the tranny fluid was for life? With the Mercedes I have owned, they always have tranny fluid and filter listed as a maintenance item.
Old Dec 18, 2023 | 09:26 AM
JettaRed's Avatar
Veteran: Army
Hi all,
Get a Mercedes specific scan tool, such as iCarsoft MB V3.0, LAUNCH Creader Elite BENZ, or Foxwell NT510 Elite so that you can scan your car at any time.
Not sure if this applies to your car, but Mercedes generally recommends suctioning oil through the dipstick tube using a vacuum device, such as a MityVac. The oil filter should be on the top of the engine, making oil changes fast and easy. Diehards will say to drain from the bottom, and that is an option, but the plastic drain plug makes me nervous. Confirm with the dealership how they do it.
The other thing I would caution is to not go 10,000 miles between oil changes. While it's the distance interval specified, I worry how much of that is sales driven versus engineering driven. Since all cars today claim 10,000 miles or more, or even calculate when you need to change the oil based on how you drive (i.e., Honda), how much crap do you think a manufacturer would catch if they said change the oil every 5,000 miles (and we'll do it for $300)? Oil and fluid changes are cheap insurance.
Old Dec 18, 2023 | 11:49 AM
RA040624's Avatar
GLC
Hi all,
Just returning the comments from my above post on the option for resetting the oil service code.
So for an update it appears that in the 2024 models they have taken away that feature, unless something pops up on on the info channels
So for now I only can see two options; take the car into the dealership for a the 10,000k oil change, buy a scanner tool.
so unless this appears on any new videos coming up from anybody that might know.
I probably will go the ODBC to scanner route for resets in the future. It's a real shame that auto manufacturers are controlling our simple maintenance habits or in some cases even adding insult through them by throwing service codes if you touch something. Just My two cents.
Old Dec 18, 2023 | 09:14 PM
W205C43PFL's Avatar
I have bad memory but I believe it was the W210 when they did that, which backfired.
