2011 E550 Driver side power seats
Old Dec 18, 2023 | 05:27 PM
rzdave12's Avatar
E550 2011
Out of the blue, the drivers side power seats including front/back, seat tilt, and headrest up/down, and memory 1 , 2, and 3 do nothing. While the passenger side seat is all working fine. Checked all fuses as listed on fuse guide and they are all good. Checked all connectors under the seat, they are connected properly. What might the problem be? Perhaps a relay? Anyone have any idea what to check next? Different motors control different parts of the seat so no way all 3 motors failed at the same time. Any suggestions?
Old Dec 18, 2023 | 07:27 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
Goofy driver Seat
Driver seat no longer operates.
You want to scan your car modules to retrieve live faults.
-1- More than likely your issue is with the DCU control Module not the actual modul under the seat. This one is built well.
-2- Other related issues are poor GND either footwell or seat.... Need to scan to know what grumblings are at play.
Seat are a safety device during accidents. You best interest is to have that working.
Time involved ~ 4Hrs.
Hopefully things pan out well.
Old Dec 19, 2023 | 12:10 PM
rzdave12's Avatar
E550 2011
Where is the DCU control module located in this vehicle? And wouldnt that module control both driver and passenger seats? Is that the unit on the driver door itself? I tried googling DCU E 550 but nothing comes up. I am not an automotive expert so I apologize for the rudimentary question.
Old Dec 25, 2023 | 01:39 PM
>> Indide each door in the forward section.
>> Each door has it's very own controller .
>> Yes exactly, right there.
>> Once you ise a svanner youll be able to read its part numbers for search.
Pls find my answers within your questions. Get in touch with a Mercedes specialist that will get things work for you.
Parts are cheap, specialized labor is not.
