---> CALI's hands-on ... STABLE CHASSIS VOLTAGE !!!
Old May 7, 2025 | 05:58 PM
  #876
W205C43PFL's Avatar
6Bar is near 90psi !!!
Sonno leak more like stuck proportional valve issue.
I don't see any leak though, uh oh.
Old May 7, 2025 | 05:59 PM
  #877
W205C43PFL's Avatar
The specified value is 0-35 bar so I am not sure
Old May 7, 2025 | 06:00 PM
  #878
W205C43PFL's Avatar
MS had a thread too, had an issue with the sensor showing 29.5 bar, after the replacement of the sensor it shows 7-8 bar.
  #879
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
no leak !
Does the A/C conduit get hot or cold.... could be bad blending door module
Old May 7, 2025 | 06:04 PM
  #880
W205C43PFL's Avatar
no leak !
It is strange actually if I turn off the a/c I get somewhat cold air, I mentioned somewhat is because it is not cold air at all but just colder than the air from outside. If I turn on the a/c, the air is warmer than when I have it off, and the air feels more like the air from outside. I checked with the scanner and the button is functioning correctly, as in closing and opening the magnetic clutch and calling for a/c correctly. So I am not sure what happened. I mean, even with a/c off with the colder air, it can't really be considered a/c, the temperature is set to LO, system airflow, direction, speed all set to auto when I test this, it immediately blast the blower motor to max.
Old May 7, 2025 | 06:07 PM
  #881
W205C43PFL's Avatar
not sure why the link wasn't included, sorry about that: https://mbworld.org/forums/e-class-w...mum-speed.html
Old May 7, 2025 | 06:31 PM
  #882
JettaRed's Avatar
Veteran: Army
The Schrader-type valves on the high and low ports could be a source of leaks and it won't be visibly apparent. Low refrigerant can cause the evaporator to freeze up (literally). To much pressure can cause the compressor to turn off (safety issue). Sounds like time for a trip to Harbor Freight (or Canadian equivalent or Amazon) for a set of HVAC gauges. The proper way to diagnose an a/c problem is reading the high and low-side pressures.
Old May 7, 2025 | 06:32 PM
  #883
W205C43PFL's Avatar
I just realized I might had messed with this at some point, what is this turn knob thing?
Original image: https://images.pistonheads.com/nimg/..._AMG_011-L.jpg
Top left corner.
Old May 7, 2025 | 06:43 PM
  #884
W205C43PFL's Avatar
https://cimg5.ibsrv.net/gimg/www.mbw...d4e05a8af3.png
https://cimg1.ibsrv.net/gimg/www.mbw...bbd8fd487c.png
https://cimg8.ibsrv.net/gimg/www.mbw...e6885e19e2.png
Thank you forum member JettaRed!
Old May 7, 2025 | 06:45 PM
  #885
W205C43PFL's Avatar
Any idea what that turn knob is though, it seems to be connected to the a/c conduit though.
Old May 7, 2025 | 06:46 PM
  #886
W205C43PFL's Avatar
no leak !
Oops sorry missed your question, I forgot to check : (
Old May 7, 2025 | 07:08 PM
  #887
W205C43PFL's Avatar
That turn knob is to recharge refrigerant. I think I am starting to know what happened, I recall messing with this last year curious what it is, maybe I left the cap loose and the refrigerant leaked out. Thanks both for your help.
Old May 7, 2025 | 07:09 PM
  #888
JettaRed's Avatar
Veteran: Army
Top left corner.
Need a bigger picture. Maybe use MS Paint to identify what you are talking about.
Old May 7, 2025 | 07:11 PM
  #889
JettaRed's Avatar
Veteran: Army
Is this what you are talking about?
Old May 7, 2025 | 07:16 PM
  #890
W205C43PFL's Avatar
Sorry about that yes it is that.
Old May 7, 2025 | 07:18 PM
  #891
W205C43PFL's Avatar
Yes, that is where you recharge refrigerant I figured, I probably left the cap loose last time and it evaporated?
Do you think I still need the full set of professional hvac measuring tools or simply a recharge can with a meter, if so which one do you recommend? Or what is the oem part number by chance? Thank you : )
Old May 7, 2025 | 07:24 PM
  #892
W205C43PFL's Avatar
One thing that is also still not clear to me is why is the air temperature coming from the vents lower when a/c is off opposed to when a/c is on.
Old May 7, 2025 | 07:44 PM
  #893
JettaRed's Avatar
Veteran: Army
Those are just caps and the Schrader valves are beneath. Not sure which is the high side and which is the low side, but they are different sizes and the gauges can only connect to the correct line. Here are the caps on my C350 and SL400. On other cars, the caps are sometimes blue and red.
C350
C350
SL400
SL400
Old May 7, 2025 | 07:49 PM
  #894
W205C43PFL's Avatar
C350
C350
SL400
SL400
Much appreciated : )
Old May 7, 2025 | 07:50 PM
  #895
JettaRed's Avatar
Veteran: Army
Does the air get colder immediately? Or after a few minutes?
Also, futzing around with the caps doesn't hurt anything. I think they are there to keep dust and dirt out of the valve, not to hold pressure. You may do well to take the car to an A/C specialist if you don't want to mess with it. If any repairs are needed, you need to go to a shop anyway because they collect the refrigerant with special equipment. In the US, it's a violation of federal law to vent the refrigerant to the atmosphere. Plus, you don't want to inadvertantly breathe a lot of that stuff.
Old May 7, 2025 | 07:51 PM
  #896
W205C43PFL's Avatar
Well, what do you know, the same day I am dealing with a/c problems on a W205, another forum member posted this thread: https://mbworld.org/forums/c63-c63s-...t-located.html
Guess I wasn't alone after all.
So is it possible for the refrigerant to slowly leak if I left a cap loose? Or it can only leak through a crack in a hose or something
Old May 7, 2025 | 07:56 PM
  #897
W205C43PFL's Avatar
Solid advice, I see, if it wasn't the cap then maybe I do have a leak just can't find it. Thank you I might have to bite the bullet and go somewhere to get it fixed. I really hate leaving the vehicle overnight or away from me though. Reason why I like to diy but this is something I shouldn't diy I guess.
Old May 7, 2025 | 08:14 PM
  #898
JettaRed's Avatar
Veteran: Army
If the Schrader vavle is leaking, the cap only slows the leak, it won't stop the leak. I had to replace the valve on my 2000 Ford F150 last year because it had begun to leak. They are like the valve on a car tire or bicycle tire. The valves are replaceable. The problem is that you have to evacuate the system and capture the gas. The after repairs, you need to run a vacuum pump for quite a while to evacuate the system of any air that got in. Once that is done, you then add exactly the amount or R134a that is specified on the sticker in the engine compartment. If you don't want to invest in all the equipment you'll need, then taking to an A/C specialist is the way to go. AND, the problem may be something else. If you want to know for sure, you can get some dye to add into the system and then use a UV light to look for any leaks. Most auto parts stores or Walmart or Amazon have the dye leak detector kits.
Old May 7, 2025 | 08:21 PM
  #899
W205C43PFL's Avatar
Thanks for the tip, guess I have some researching to do tonight.
I'll get those.
Old May 7, 2025 | 08:35 PM
  #900
there is a special A/C tool to replace schrader valves without opening the circuit. First see if they are leaking.
Big pipe is low pressure cold-return to compressor
Skinny pipe is high pressure hot-side to expended coil.
Feeding is done only on low-side, the compressor suction side.
I think this is had to do with Compressor valve issue (not TXV).
