MBWorld.org Forums
MBWorld.org Forums (https://mbworld.org/forums/)
-   Mercedes Tech Talk (https://mbworld.org/forums/mercedes-tech-talk-41/)
-   -   95 E320 won't crank (https://mbworld.org/forums/mercedes-tech-talk/91033-95-e320-wont-crank.html)
kg95e320 Dec 7, 2004 04:17 PM
95 E320 won't crank
Cold start, happened suddenly - Inserted key, turned all the way, all lights came on, seatbelt buzzed, radio played, but engine didn't crank. Battery is 6 mos. old, tried jump anyway. Same thing. Ideas? Thanks, KG
E320Star Dec 7, 2004 04:21 PM
Take it to a qualified mechanic. Make sure they Check air flow meter. :hammer:
vinamg Dec 7, 2004 05:49 PM
Sounds like a faulty Park/Neutral safety switch. Try putting it in neutral.
kg95e320 Dec 7, 2004 09:54 PM
That's the ticket. Found out through a few sources, then tried it. It's also a $45 part that can be installed fairly easily, depending on one's comfort in getting underneath in a tight spot by the tranny. Thanks.
© 2026 MH Sub I, LLC dba Internet Brands
