Mercedes cla 250
Old Apr 13, 2025 | 10:56 PM
Zaidnoel's Avatar
Mercedes cla 250
So, I took my car to a mechanic, and he said I have a vacuum leak. He told me I need to replace the whole part, but then I went to another mechanic for a second opinion, and he said I only need to replace only these two parts. Can anyone help me figure out what those two parts are? Also someone else told me that it’s also the fuel rail pressure sensor where the putty is at circled that’s the part I need. Any advice would help
Old Apr 13, 2025 | 11:17 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
I am not sure what you're trying to fix.... you say a vaccum leak.
A good MB specialist would fix your issue quickly with no second thoughts.
broken intake plastic
Knowing your intake air duct is broken possibly leaking is half the battle.
Researching the right part number to source where it may be available will be not simple... not around the corner parts store.
Old Apr 13, 2025 | 11:21 PM
Zaidnoel's Avatar
a mechanic told me to buy this part but not sure
Old Apr 13, 2025 | 11:43 PM
this NEW part does looks like a nice quick solution for a tiny price and you also get its part number.
Old Apr 13, 2025 | 11:45 PM
furthermore.... root cause:
WHY is the intake cracking....
Wasted engine mounts ??
Old Apr 13, 2025 | 11:50 PM
Zaidnoel's Avatar
do you know what part I need to buy
Old Apr 13, 2025 | 11:51 PM
Zaidnoel's Avatar
Old Apr 14, 2025 | 12:16 AM
powertrain mounts
that's a lot easier because these are "standard" parts with countless suppliers unlike your intake tube.
Look at supplier of your choice
or forum partner: pelicanparts.com
or "FCP EURO dot com"
or directly from MB website for "best quality".
What you want is :
2x engine mounts
1x transmission mount
All these 3 parts at the same time.
Really cheap parts until branded with Mercedes seal.
This will preserve your new "plastic intake" from braking again shortly and help control engine shaking.
Old Apr 14, 2025 | 01:47 AM
Zaidnoel's Avatar
What you want is :
2x engine mounts
the plastic piece broke by my son he was messing around with my car. I just need to get it repaired
Old Apr 14, 2025 | 02:25 AM
Good deal, son broke it...
get him a scanner so he can lear how 40+ modules run.
Old Apr 14, 2025 | 02:28 AM
Zaidnoel's Avatar
hey man no time for jokes. Can you help me get this solved
Old Apr 14, 2025 | 05:42 AM
Nothing to solve:
It's all sorted out
the part supply you posted earlier.
Old Apr 14, 2025 | 05:51 AM
W205C43PFL's Avatar
Perhaps more than 40 actually : )
Old Apr 14, 2025 | 05:53 AM
W205C43PFL's Avatar
It sounds like you are all set, you have all the part numbers ready and just replace away.
Old Apr 14, 2025 | 10:59 AM
Zaidnoel's Avatar
Nothing to solve:
It's all sorted out
which part would that be
Old Apr 14, 2025 | 11:00 AM
Zaidnoel's Avatar
what part would I need
Old Apr 14, 2025 | 11:42 AM
W205C43PFL's Avatar
That part in the picture you shared with us, is that it?
Old Apr 14, 2025 | 12:12 PM
Zaidnoel's Avatar
yes but idk what part to buy
Old Apr 14, 2025 | 01:07 PM
Go to the parts sales at your Mercedes dealer
show them this picture.
Mercedes-Benz will order the exact genuine part for your vehicle.
It won't cost $98 your car needs good parts, not eBay copies.
Old Apr 14, 2025 | 01:17 PM
Zaidnoel's Avatar
oh yeah I know this was all that I could find online
Old Apr 14, 2025 | 04:00 PM
W205C43PFL's Avatar
Perhaps you may also post the VIN and someone with WIS (workshop information system) and electronic part catalogue (EPC) can look up the needed part. I would love to run the VIN for you but at this moment I have no access to both of those systems.
That said, this part seems to be the correct one, did you try to order it and see if you can install it?
Old Apr 16, 2025 | 09:06 AM
JettaRed's Avatar
Veteran: Army
I don't see the "J" shaped part in the picture of your intake you first posted. Before throwing parts at the car, I would want to make sure I know where the leak is occuring. So, a couple of (obvious) questions:
1. How do you know you have a leak? Did you get a CEL? What other symptoms?
2. Did the mechanic run a smoke test? Did smoke come from under the putty?
2. What is under the putty? Can you remove it and show us? Who put the putty there?
If there is a crack in the intake tube, I would try some JB Weld for plastics first. I never believed the stuff works until I used some to replace broken trim pieces when replacing the headliner material in my Audi TT.
Also, the comment about getting a scanner was no joke. A proper Mercedes-specific scanner like the LAUNCH Creader Elite 2.0 BENZ is probably the most important tool you can buy for your car.
